Originally Posted by Terraphantm
Front calipers are the same. Carriers are the same as the ZCP/CSL (i.e sized for the 345mm rotors). To use non-CSL/ZCP rotors, you need to retain the stock M3 carriers.
Rear calipers and carriers are different (pistons are 46mm instead of 42mm). They will fit the M3, but would move the brake bias significantly rearward (and thus would not be recommended without the front 345mm rotors)
The rear ZCP/CSL E46 M3 calipers also use the same 46mm piston as the Z4M. In short, the Z4M brake system is identical to a ZCP/CSL E46 M3.
I agree, if you're going to use the Z4M front calipers, be sure to pair them with the Z4M/ZCP/CSL rear calipers.
Originally Posted by SDMCoupe
So for the rear brake lines I can reuse the existing M3 lines or transfer the rear lines from the Z4M to the M3 (or neither option)?
Yes, you can reuse the M3 rear brake lines.
