Originally Posted by SaltyNC
Pip, it looks like you'll need to the DSP solution since you have the coax cables. At least the wires are exposed. I have the newer cable set, so I'm not familiar with the function of the connectors you're showing. Sorry.
I don't know if it will be any help to you, but I did go ahead and update the DIY on tearing out the interior and got the pictures moved over to Imgur.
http://www.zpost.com/forums/showthread.php?t=1230786
Best of luck on your project.
Salty
thanks for the update and replacing the pics - it looks almost as bad as replacing the heater matrix/heater fan on a volvo 240 -
http://cleanflametrap.com
the car was built round it!
