Originally Posted by inTgr8r
Originally Posted by F360C
Basically if I had to imagined the perfect front aero solution for our cars this is exactly what would come to mind.... Well done sir!
I have been running your front filler piece for the apr splitter for years now..... finally after years of abuse it has cracked a little in the center. I think it is sign now that you might make a couple of these.
Thanks
At one point I was thinking about something a little more simple.
Same basic lip shape but without the vertical sections on the wheel wells, and then run canards to cover off the the front tires.
It was the GT3 that provided the idea to attempt the fully integrated look.
This is--wow--I can't fully describe it!
Yes, I see the GT3 influence. It works so well here!
Great stuff--keep it coming!
