Originally Posted by DaveJB
I hate to dredge up an old thread but I figured this would be the best place to ask.
I ordered a set of Fortune Auto 500 coilovers with Swift springs and the radial bearing for my 07 Z4 M Coupe. I'm confused about the rears. Are they coilovers too or is the spring seperate? Also, did it come with a top plate (rears) and if so is it worth upgrading to the Rogue RSM's? Any chance someone can post some pictures of the rears out of the car?
Thanks
Can't run true coil overs on the rear without significant modifications to the rear shock towers like a full cage. Simply not strong enough to deal with the forces stock. So it's going to be a shock and a separate spring.
While you're in there yes I would do Rogue RSMs unless the top play lets you bolt and in bolt from the wheel well. That's what the Rogue benefit is (better compliance too from stock). You only want to disassemble and reassemble the hatch area once.
