Salty - which item is the common failure point? The engine mount or the support bracket?
Originally Posted by SaltyNC
Are you talking about the engine mount or the support bracket that connects to the engine block? The engine mount has new bolts as part of the assembly. It is a good time to upgrade the bolts that hold the support bracket on the engine block.
McMaster-Carr is your friend (mcmaster.com):
90854A167 High-Strength Zinc Yellow-Chromate Plated Cap Screw, Class 10.9 Steel, M8 Full Thread, Pitch: 1.25, 25MM LG
90854A172 High-Strength Zinc Yellow-Chromate Plated Cap Screw, Class 10.9 Steel, M8 Full Thread, Pitch: 1.25, 35MM LG
Salty
