Originally Posted by The Hunter
Thanks. I know how to swap a strut brace, but no longer have my E46. Just looking for others perspectives since I’ve heard others have had trouble fitting the E46 brace.
You will need to remove locator pin from the z4 strut towers to clear the bracket:
But that's the only "mod" you need to do. Make sure you get correct centering nuts for the brace, regular shock nuts won't work:
https://www.ecstuning.com/b-genuine-...h/51717895241/
You need 6, but if you shop on ebay, sometimes braces already come with these, so saves you $65.
