Originally Posted by DRedman45
exactly, those brands are great for budgets...fortune is quite a bit different, than those brands. The components are manufactured in taiwan, but each shock is build to order in the US using valving based on the spring rates you choose. And even better, the are rebuildable in the US, which is an issue I have a bit of secondhand experience with from a couple of the cheap asian built coils.
I will get some much better feedback once I get them on. But for now, I can say with certainty Fortune's build quality is on a tier above BC, stance or any other $1k coilover....and better than most $1.5k coils
By China I also meant Taiwan, really not that much different. Fortunes come from the exact same factory as some of the "other 1k coilovers". They are literally the same thing in a different color.
Being assembled in the US isn't really much of a benefit, and unless you are going WAYY out from the default spring rates, a re valve is not really necessary.
