Originally Posted by dbarton62
Yep, most of these issues are present with my 3.0
I have a used cluster incoming to rule out that.
GM5 is good. New ignition switch installed.
There are 4 things that create the loop for the body.
Cluster
Ignition switch
LMZ...Light switch module
GM5
Also frayed wires to ground is a definite possibility.
You bought the entire cluster? used or new?
Have you checked for any codes? I'll post the codes my car is throwing. I did post them on the thread i started months ago but it got complicated for my understanding.
