Thread: Firearms
      11-15-2019, 08:43 AM   #3674
MR_X
Old guy
308
Drives: tricycle
Originally Posted by pennsiveguy View Post
It's easy to forget how important that is, since most of us go to the range only during the day. Firing any gun makes a flash, but some are worse. I fired a .44 mag revolver in pitch black once. The flash from the gasses coming out of the cylinder-barrel gap goes out like a sunburst. I couldn't see shit for about 5 seconds. Really drove home the importance of flash management. The ports on this one do look like they're out the sides, so that would help. The old upward-facing Magnaport ports would have been awful at night.
MOST defensive ammo is made to reduce flash for this very reason but barrel length does make a difference too. Flash comes from 2 things, unburnt powder (which is what you see in revolvers cylinders) and slow burning powder that are mostly use in Magnum calibers or heavy bullets to get more velocity. So revolvers you get the worst of the 2. Of course when you pair this with a short barrel you get flash.
Shoot a 44 Special out of your 44 Magnum in the same circumstances and see if you get the same effect.
Another way to get around flash blindness is to add a a flash light.
