Yes I cant use any databus like canbus.
Cars used to have a D+ on the alternator (for example used to control the run engine light) but the m54 engine already has an ecu controlled alternator so that doesnt work. I measured the voltage on that d+ connector but its not DC (dc 7,5v ac 5,8v) so some kind of complex signal that also isnt set on/off with the engine.
On modern campervans they sometimes use a D+ simulator (d+ is used there also to switch a fridge on/off) and such simulators work on the battery voltage (so they swich on/off at 13.5v or so), but that is way to unreliable for my project.
