      04-24-2019, 10:22 AM   #79
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Originally Posted by gmd2003 View Post
Good luck finding a car that only has an oil temp of 194 during 20 min at full pace on track ! In the real world I was able to limit my oil temps to the 240's even on hot 80 plus southern humidity conditions making 500plus hp with a 34 row setrab oil cooler. With the proper oil that is acceptable and my 40k track miles confirms that . Bearings in stock form are too narrow on the S54 and you will have wear at any temp , even on the street . That's why I went with the Lang racing widened bearing setup after my vibration damper failed and I was tearing down to look for bearing wear anyway .
G
With a CSF front mounted Oil Cooler and no FI, oil temps still hover around 250*F towards the end of a 20min session on track. I agree with you, this sort of wear will occur regardless of street or track driving.
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red |
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage
Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo
