I'm 23" or 584mm on the rears, measured from the bottom of the rim up to the fender, which is a 10mm drop from the stock ride height of 594. The rear wheels still seem too cambered, by my visual estimate.
Front is 23.8" or 604mm, which is close to the stock height of 607mm. So i'll probably drop it a bit more, till it's a 10mm drop all around, then take it for an alignment.
