I've been using the Centric parts (same mfr as Stoptech, just not slotted and/or drilled) with good results.
Cheap from Rockauto -- $48 each for the rears and $41 for the fronts
2007 3.0si Coupe
Dinan Stage I Suspension (Shocks, Struts, Springs), Ground Control Front Camber Plates, Treehouse Racing Front Control Arm Bushings, RTAB Bushing Limiters
