      12-07-2019, 10:33 AM   #46
MKSixer
MKSixer's Avatar
34186
Drives: 2015 BMW i8, E63 M6, 328d
2016 M4 GTS (Allotted)  [0.00]
2013 BMW 328d  [0.00]
2007 BMW M6  [10.00]
2015 BMW i8  [10.00]
Originally Posted by Salty Dog View Post
I've only seen snippets of the pursuit and gunfight. Frighting. I was hesitating whether or not to weigh in as these things always get quite animated. Folks have very strong views on everything LE does.
I've probably been in more than 2 dozen pursuits, some went text book and other turned into demolition derbies. Just about every single one ended with the suspect involved in a collision, often very serious.
Some of the pursuits lasted over an hour and others just seconds. Just about the most unpredictable things you can imagine. The training has gotten much better and so has policy which generally varies from agency to agency but it has been evolving over the years. Some departments use PIT others forbid it, some have stop sticks others do not.
The one thing I can say for sure is nobody knows how it will end, and the police are usually in a very bad position regardless of what they do.
Sorry if that's long winded but I could literally write a book on this topic.
Sharpen your pencil! You have been Prancercised making you a fully initiated member so you don't get to walk away that easily.
I realize that MM quarterbacking is horrible, especially on this topic with the added negative of no real footage. That said, what do you think could have been done better knowing the information you have vs. your experience.
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion.
minn1914052.50
