Originally Posted by Jumbosock
Do you have a bulb out light on your dash? The halo LEDs I used gave me a light on my dash.
Actually, I did change out my halo bulb to an led when i did a projector upgrade for the low beams. Did get the bulb out warning and coded out with Carly. Coded everything out at the same time so not sure if the rear lights triggered the warning too or not. I coded everything out because I was getting the hot and cold light check show with the LED's.
