Originally Posted by Angry-cop
That sounds really good!.. Did you leave the Gopro out of its case to plug that mic in? Or do they make a special case that has an opening over the mic jack?? I also have a Hero HD 2 and my biggest gripe is the sound and the location of the External mic jack... And another question that Mic you bought does it come with a long cord? It looks short on Amazon?
I'm also running an external mic. I drilled a hole in the case, since I have a dedicated flat lens underwater case anyway. You could also buy a "skeleton" housing. I've tried MANY things to eliminate wind noise, and none worked as well as putting the mic on the back bumper near the license plate, far away from the wind stream. Putting it under the hood or in the interior isn't as impressive for sound. My mic also only starts picking up at 100hz, which I don't think is low enough to capture the proper low frequencies of the exhaust
