Recently installed the Bilstein B6 dampers, Lemförder front mounts and Rogue Engineering rear mounts. Stupid me, I missed the fine print on the Eibachs and they were for the M, so they didn't go in. Too bad; the drop would've been perfect (20/10mm) but the right springs are 30/30mm and would've required exchanging the shocks, adding endlinks, yada yada - and I was in a time crunch.
2008 BMW Z4 3.0i - "If you have to replace it, make it better."
