Originally Posted by 3GFX
That's a good thing, I had lots of rubbing with 245, but the offset may not have been correct. If you haven't already...post your specs!
Both me and unluky have the same model car as you and we are running 245/35-18 on our fronts with plenty of clearance without adjusting the camber. I'm lowered on Eibachs and use a small 5mm spacer up front (its actually 7mm after you take into account the extra 2mm offset from my aftermarket wheels). I believe unluky has H&R's and uses a 15mm spacer up front. The key is to put it on a 8" rim. Did you try using a 8.5-9" rim?
