Originally Posted by rsrider
Hey guys, needing some confirmation on tyre sizes for my new wheels on the Z4M Coupe if at all possible. Have read through every page of this thread and no one has the exact setup I am looking at.
Basically I am wanting to know what the widest front and rear tyre I can run is without experiencing any rubbing issues on both standard suspension and also Eibach Pro springs.
Would 19x8.5 ET35 with 245/35/19 fronts and 19x9.5 ET22 with 275/35/19 or 285/30/19 rears work?
Wheels are Apex ARC-8.
Thanks in advance!
I have the exact wheel/tire specs for the front and it should be no issue. I have 19x9.5 ET25 with 275/
30/19 and there appeared to be only about 5mm or so clearance to spare on full/near full compression (I'm running Continental Extreme Contact DW). My guess is that I will be a tight fit with 275s on an ET22. But then again, it all depends on the tire brand as not all 275 tires measured equally across different brands. I'm almost certain that 285 will rub on ET22.
