Originally Posted by auggiem3
I just got a good rate at a relais & chateau property in Milford PA - a little less than 30 miles from Monticello and only a few minutes out of the way from DC.
It's called Hotel Fauchere.
If you haven't seen the Relais & Chateau properties, you'll like them. Inn at Little Washington is a good example.
how much is that place? I'm booked at the Best Western Monticello which is right next to the track
what day are you going? I'm on for Tue, 8/21
