1998 M3 Sedan
AFE Intake
Conforti Corsa Exhaust RSC-36
UUC Evo3 shifter w/ optional double shear selector rod (DSSR)
UUC Clutch Stop
UUC Swaybarbarian swaybars
UUC Transmission mounts red
Stainless Brake Lines
Stainless Clutch line
PWR Aluminum Radiator (from Bimmerworld)
Stewart High Flow Water Pump (must for track cars, IMHO)
All new coolant hoses, water pump nut wired, new oil pan gasket, belts & motor mounts
Ground control RTAB Shims
Powerflex Front Control arm bushings
Strut Hats swapped L/R for -2.5 – 2.75 camber in front
Calipers Rebuilt Bimmerworld kit
Replacement Rear Koni’s from Tom life time war
E36 Ground Control SA Coil-Over Kit Track/School (SPGC) (400; 450)
3 Series Rear Shock Mounts - Urethane/Al, Street/Track E36 and E46 ONLY except conv (updated design)
Aluminum Thermostat Housing All M50 EXCEPT E39 528
Turner Motorsports Antiroll bar reinforcement kit welded in by Butler’s as were 360 degree welds around RTAB 3 mounting points on both sides.
Race type wheel studs and lugs from Bimmerworld
5mm spacers in front
8 17 x 18.5 D force wheels anthracite
Winter floor mats $90 12/08
Final Stage Resistor & Capacitor control unit (controls A/C Unit)
BMW Car cover
Bimmerworld 9-10.5 Strut-Mounted Adjustable Swaybar End Links
Bimmerworld E36 Fule Starvation Kit
Bimmerworld Oxygen Sensor Simulator
PFC Direct Drive Rotors Kit – Discs Replaced 8/15 - Wheel bearings done at same time
- Have rear wheel bearings that will go with car
Bimmerworld solid Brass Brake Caliper Guide Bushing Kit
71 degree thermostat
Fan Delete – Have all orginal parts
ASC Delete – Non-ASC Intake Boot
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor
