      04-04-2019, 02:34 PM   #306
TheWatchGuy
TheWatchGuy's Avatar
3905
Drives: 335xi
Originally Posted by RickFLM4 View Post
That's what I figured and I expect it will be hard to get an exact match. Pictures aren't precise enough and even a small sample from old leftover vs. a slab is probably hard to compare, even though the granite we have was extremely common back in the day.
The problem is that even when replacing the entire counter, it is right next to a granite backsplash and granite bar counter. So if a mismatch is noticeable, it will be noticeable even if the entire counter is replaced.
Carpenter / cabinet maker coming over tomorrow to scope out kitchen cabinet refresh or new cabinets. If we are going to do all new counters then we ought to think about cabinets at same time I guess.
the backsplash and bar wont be as bad since its not 1 slab. You match the colors right, and it wont be weird.
when you try and replace just a section in a slab, its very noticeable because patterns wont line up and youll be able to see any color difference as well.
@drunkcowatches on ig
Am I a watch guy, or do i watch guys?
RickFLM410998.50
