      05-23-2022, 05:30 PM   #400
HeelToeShift
Drives: Mine
Originally Posted by Bubbles View Post
According to the FIA, Red Bull struggled with low fuel temperatures. The limit is 10C below the outside temperature, Red Bull fuel was 25C degrees below and only reached the required value shortly before leaving the pits. In Miami, the fuel temp limit was fixed limit of 18C. But apparently Ferrari vetoed this limit because the Mercs and Honda PU are said to not tolerate the warm fuel as well as the engines from Maranello.
The teams do not agree on when it is illegal to use fuel that is too cool. The rules say: "When the car is in use". So when the car is used. Aston believes this moment with stepping out of the garage. Ferrari sees the fact that the car is being used as soon as the engines are started.
Max’s DRS was a new prototype that weighed less than Checo’s. It failed.
Russell was moving a bit in the braking zone on both Checo and Max. This will likely be less tolerated in the future.
Russell was definitely driving dirty with his moving from the far left to the middle to cut off Max and give him nowhere to make a move. He knew he was getting passed by Max no matter what - he just does not have Max's pace on track.
