      09-22-2020, 11:46 PM   #16
RM7
RM7's Avatar
2898
Drives: Camaro SS 1LE
Originally Posted by Emilime75 View Post
Still does not explain why one would have to buy multiple tires of one goes down, that's what I was questioning. I get the potential of having to replace 1 tire, but why a pair or all 4?
A large % of cars are all-wheel drive and you can't have one or two tires out of tread-ware spec. It's unlikely that you are going to replace just one due to tread-wear. Whether it's side-to-side treadwear or back/front. If you do replace one, it's because you shave down a new one, if your shop will do that, but even still, you are paying the run-flat premium on that one tire. Unless you are installing your tires yourself, most shops won't let you install something against manufacturer recommendations.
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
