Another small project that I wanted to knock out. I made these laminate panels with 8 plies. No foam core. I wanted them to be thin for jack clearance and be tough in case of impact. I riveted these in place using a 1/8" spacer on the outside edge of the rocker to make the side skirt close to level. Otherwise, it will point up a bit. Would still be functional but would be an odd aesthetic.
Hopefully these will compliment the flat floor.
