Originally Posted by MBan
Thanks, m-cast - that’s a serious looking M Coupe!
Rotating tyres is one reason i’m considering a square setup for the street. I won’t be putting many km on the car and the front tyres may even pass their use by date before running out of tread.
Is there any reason to NOT run a square setup on the street?
I’d like to run a 255 tyre all ‘round but suspect that wouldn’t fit on the front without body work and/or serious alignment settings?
Cant comment on square setups much but Im running a 255/35/18 in the front on stock suspension and don't have an issue with rubbing. A different tire may change that completely but I'm running Michellin PSS and they've been perfect so far.
