      05-23-2014, 09:18 PM   #1
Petrosexual
Drives: M Roadster
Electrical issues, airbag errors traced to faulty ignition switch
I recently had a handful of electrical problems crop up in my 06 roadster, all at once: radio cutting out, MFSW controls dead, random airbag errors, passenger seat occupancy sensor error ( flashing diabled light), heated seats and DSC control would only work intermittently. This coincided with the OEM battery dying and being replaced.
Indy shop could not determine a cause. We suspected the sping switch in the steering column. Finally bit the bullet and wheeled it into a dealer ( Valencia BMW) for a full diagnostic.
Culprit turned out to be a faulty ignition switch that was disabling some of the other systems randomly, and causing a fault code storm throughout the car. Go figure. Parts and labor to replace same, about $480.00, all issues resolved. Chalk one up for the stealership.
      05-23-2014, 10:34 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
So GMs aren't the only cars with faulty ignition switches that disable the air bags.
Tags
airbag, ignition, mfsw, occupancy sensor
