      04-16-2014, 06:52 PM   #1
papak
Drives: 2008 Z4 3.0si Coupe
Aluminum interior trim removal
How do I remove the aluminum interior trim in my coupe? Looking to having it wrapped or painted.
      04-16-2014, 07:28 PM   #2
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Did you
I did. For You.
http://www.zpost.com/forums/showthread.php?t=339707
      04-26-2014, 06:17 PM   #3
papak
Thanks. I saw this thread but it provides almost no guidance.
      04-27-2014, 04:42 PM   #4
speddmn
Drives: 05 3.0i
the light switch bezel comes out after you pull the left vent/cupholder (pop off the little screw cap thing at the top of your vent then another insidethe cupholder bit IIRC)
The big panel comes off after removing the radio, center vents and a tricky pin kind of clip behind the right edge... remove the vent, become a contortionist, you'll find it
The console panel is the real beeeeeya - remove the rear glovebox thing, remove the ashtray panel, remove the kneepads, undo all the bolts, wiggle it out then remove 400 more screws
search will help you see how to pull each part... good luck, bout to do this the second time myself and it's not that fun.
bags are for groceries.
      04-27-2014, 09:56 PM   #5
papak
Thanks. I'll give it a shot in a week or two.
      04-23-2015, 06:07 PM   #6
JCF
Drives: 07 Z4 M Coupe
I just did the dash trim this afternoon and wrapped it in CF. That pin on the right side was obnoxious. There was a round washer on the thing as well from who the hell knows where. There was some swearing involved.
Tackling the center console this weekend. I anticipate more swearing.
      04-23-2015, 06:29 PM   #7
Steeler
Steeler's Avatar
2429
Grab a jar.
You will be able to afford real CF after getting that beeeeeeeyach out
      04-23-2015, 09:53 PM   #8
JCF
I got ambitious..... Center console is done but dear lord. So...many....screws.
German overengineering at its finest.
Pics when it's daylight
      04-24-2015, 09:04 AM   #9
JCF
Finished product. Sorry for the glare in the picture.
I'm glad I did it as the aluminum trim on the console was pretty dinged up by the previous owner but man what a pain in the butt to remove all the stuff.
      04-24-2015, 01:31 PM   #10
cogriff
cogriff's Avatar
Drives: 2006 Z4MC
2014 Audi  [0.00]
2006 BMW Z4MC  [9.00]
1977 Honda CB750K  [0.00]
2007 Kawasaki ZX6-R  [0.00]
Hey! sorry to threadjack but can you provide some details on your Iphone mount and how it's connected?
The previous owner did some kind of ghetto connection in my car, it works but it sucks at the same time and there is no mount. Yours looks pretty clean.
BTW, CF looks great! I think I'm going to do this, that or piano black....
thanks,
      04-24-2015, 02:18 PM   #11
JCF
It's a proclip mount.
It's not as cheap as some other mounts but the fit and finish are worth it.
I drilled a small hole next to the Aux input and fed the cable through that. It then runs back through the console to a soundplicity that I have mounted in the trunk beside the DSP. About as stealth as I could get it.
