      01-02-2014, 06:33 PM   #1
Steeler
Steeler's Avatar
2428
Extending post cat sensor wires
Anyone have any experience with this?
I have read posts on other boards where there are concerns with
1.Ohms resistance dropping because of longer wires.
I wil be extending 12"
2.Concerns with soldering the connections because some wiring is not copper.
Is our wiring copper?
      01-02-2014, 07:23 PM   #2
Walkurie
Walkurie's Avatar
Drives: 06 M Roadster / 99 Jaguar XK8
Extending O2 wires
If you are extending to accomodate the post cat sensors from either a modified stock CAT or the Euro CAT, have you tried the basic procedure for relocating the wires? This usually works well. At least it did for me.
http://www.zpost.com/forums/showthre...&highlight=EGT
      01-02-2014, 07:43 PM   #3
Steeler
Steeler's Avatar
2428
Thanks for the link.
I did reroute the wiring as in the video.
Will try to get a bit more slack before attempting a spliced in piece.
      01-02-2014, 09:56 PM   #4
seank
enthusiast
seank's Avatar
48
I remember adding 24" and it still was barely long enough. Just use some string and route it. Then measure the string.
      01-03-2014, 12:49 AM   #5
johanness
Drives: 2008 Z4MC
Don't cut - unfold.
      01-03-2014, 05:25 AM   #6
Steeler
Steeler's Avatar
2428
Originally Posted by johanness View Post
Don't cut - unfold.
This /\ .......one lead is already longer so chances are there is slack bundled somewhere in the loom
Take a look this weekend
      01-03-2014, 06:19 AM   #7
Shipkiller
Shipkiller's Avatar
Drives: Me
Increasing the wire length does not reduce the resistance. It actually increases the overall resistance of the circuit.
Wire does not have to be only copper so effectivly 'solder' the connections. There are differnet types of 'solder' and 'flux' for different materials.
      01-07-2014, 11:37 AM   #8
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
dont cut. ask me how I know.
The Raspinator
      01-07-2014, 11:24 PM   #9
JeffchaPz
JeffchaPz's Avatar
17
Drives: 2007 Z4M
Don't cut 'em... ask him how he knows....
I pretty much damage mine by cutting them. I ended up buying a pair after months of troubleshooting. $370 mistake
      01-08-2014, 01:22 PM   #10
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
I have Euro headers by rerouting over the transmission tunnel. It is not long enough to route properly. You need to get Euro O2.
      01-08-2014, 05:13 PM   #11
Devious21
Devious21's Avatar
No_Country
38
Drives: 2006 Z4M
The shop that did my header install did cut them. I gave them all the info to extend and when they went to do it, they said they were over a foot short still.
Basically they cut them and now I'm getting strange codes everytime I fill up. I have a feeling my 02s are the culprit.
What led you to replace them? Did you do any troubleshooting to narrow it down or just bought them blindly?
|Evolve Airbox - Euro Headers - Strömung Exhaust - H&R Coils - 19" BBS CH-R|
      01-08-2014, 05:14 PM   #12
Devious21
Devious21's Avatar
No_Country
38
Drives: 2006 Z4M
Do you have part # / source for Euro 02?
      01-08-2014, 05:54 PM   #13
RobMCoupe
RobMCoupe's Avatar
60
Part number from RealOEM. I haven't look into where to source them recently. Most like will be eBay.
09 OXYGEN SENSOR BOSCH/L=1390MM 1 11787837564
10 OXYGEN SENSOR BOSCH/L=1340MM 1 11787837565
      01-08-2014, 05:59 PM   #14
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
These are the part numbers for the Euro O2 sensors:
These are the part numbers for the North American O2 sensors:
OXYGEN SENSOR BOSCH/L=1075MM 1 11781406621
OXYGEN SENSOR BOSCH/L=935MM 1 11781406622
CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights
      01-08-2014, 07:14 PM   #15
seank
enthusiast
seank's Avatar
48
You can't get them, unless you have someone over there buy them and ship them to you. BMW does not allow parts to knowingly come into the country 2 years ago.
      01-08-2014, 10:19 PM   #16
johanness
Drives: 2008 Z4MC
This is not true. You didn't route it correctly then, because there IS enough length with our good 'ol US ones.
      01-09-2014, 01:06 AM   #17
Jumbosock
Jumbosock's Avatar
76
If you watch the videos that I posted, I mention that you can't get fancy with the routing of the wires. You have to keep the route straight. I've often wondered if some wires on certain production years are shorter than others because I have heard some people say the wires won't reach. For that reason I don't say for sure that it will reach because I can't say for sure that all cars have the exact same wiring. I just know that for my car it reached and I have not had any problems whatsoever.
On a second note. I'm wondering if people should consider using the 1075mm length O2 sensor on both sides instead of using the 935mm length version. I don't *think* it would be a problem having two of the longer ones. I know for me the 935mm length side was the one that was a tad tight. Assuming the connections are all the same, the added length would help. I am almost 100% certain the connections are all the same.
      01-09-2014, 06:40 AM   #18
RobMCoupe
RobMCoupe's Avatar
60
I did not have to extend my O2 sensors by routing over the transmission. Euro O2 sensors are require to route it properly per manufacturer.
      01-09-2014, 10:17 PM   #19
johanness
Drives: 2008 Z4MC
If you want to wire your O2's the LONG way (which is completely unnecessary), then technically - yes.
But going through the cost and pain in the ass of ordering from the EU isn't needed IMO. Everyone I've spoken with who has Euro headers and have 'unfolded' their O2's have had success (read: enough length so everything connects well, with no melted wires and/or other issues).
      01-10-2014, 08:15 AM   #20
Walkurie
Walkurie's Avatar
What may be confusing for some people doing this conversion is that when unfolding the wires, one also needs to cut the loom way back to an area near the brake servo (on LHD cars) and then ROUTE THE WIRES ALONG THE DRIVERS SIDE of the engine. Have to admit it took me a bit of time to watch the video, re-watch it, and then try the whole process. If one still needs the extra length and wants to go to the Euro part numbers, try contacting these people.
http://euroactiveparts.com/OEM_BMW_accessories.php
They were able to source my Euro cats. Very easy process, came right from the OEM BMW parts distributor with no additional duty charges.
      01-10-2014, 08:28 AM   #21
RobMCoupe
RobMCoupe's Avatar
60
Link bookmarked. I plan on getting Euro O2 when I change at 100k.
      01-10-2014, 09:56 AM   #22
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Are the Euro O2s the same otherwise? (sensor spec)
