      12-04-2013, 12:44 AM   #1
se4y
se4y's Avatar
China
Drives: z4 e85
z4 e85 tire Retrofitting(for advice)
The part number of my z4 rim is 36116758191(8JX17 ET:47). The original tire is 225/45/17.My question is may I change the rear tire to 235/45/17 or 245/40/17 with the same rim? Which choice is the best if it is possible? Thanks
      01-25-2014, 05:39 PM   #2
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
Yes you can. Keep in mind changing size changes speedometer readings and is one of the reasons I usually move up at least one size in the rear in order to make speed readings more accurate. You could consider rear sizes from 235/45-17 up to 255/40-17 on the stock wheels.
      01-26-2014, 04:47 AM   #3
se4y
se4y's Avatar
China
Drives: z4 e85
Thank you.I changed 235/45-17 Michelin. not RSC. It is soft and very comfortable.The damper sound was gone. City road need soft than racing track IMO
Tags
rim, tire, z4e85
