      10-27-2013, 05:21 PM   #1
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Headliner removal tips
On my CF roof install, I found that dealing with the headliner was a little tricky.
I found out several ways that it did NOT want to come out of the car
So.... after eliminating the ways that it didn't work, I found a way that was relatively easy.
I hope the following series of pics help you a bit
1. remove the A and B pillar covers.
it helps to have proper trim removal tools, but they basically just pull off by gently wiggling from the edges & pulling
HIGHLY recommend to only do this in a warm environment.
If its cold, the plastic may not do well.
2. Remove the interior lights fixture & disconnect cable.
3. remove sun vizors .....and the front will drop down.
4. slide H.Liner towards front of car to free the back end.
5. the back right corner has to work out around the B pillar.
6. angle down and out the passenger side.
      10-27-2013, 05:49 PM   #2
itdnwiwbp
Drives: 330iZHP
Thanks for the tips!
      10-27-2013, 10:07 PM   #3
Mtxzptlk
Driving Dog
Mtxzptlk's Avatar
871
Drives: 635/1815, X3M Comp
How much time did it take from removing OEM roof to finishing installation of carbon one?
      10-28-2013, 07:09 AM   #4
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I didn't do mine all in one shot.
I pulled the OE roof ahead of time & drove topless for a while.
The most time consuming part will be cutting through the OE sealant.
and that depends largely what method you use.
I didn't try using piano wire, I used an oscillating cut tool for most of it.
With the oscillating tool the trick is to NOT try and cut the sealant.
Just make a plunge cut, then move it sideways and it basically melts through the sealant.
The corners are the hardest part to deal with. I used a long thin kitchen knife to cut the corners from the inside (fronts) and from under the hatch at the back.
I would allow a full day & just take your time with it.
      10-28-2013, 10:12 AM   #5
v3.2mc
Not a New Member
v3.2mc's Avatar
2007 ///M Coupé  [10.00]
...With the oscillating tool the trick is to NOT try and cut the sealant.
The corners are the hardest part to deal with. I used a long thin kitchen knife to cut the corners from the inside (fronts) and from under the hatch at the back...
this is exactly what was worrying me, and Vinny assured me this is the way to go. thank you for the info.
      12-23-2013, 06:46 PM   #6
zubydafa
tosser
Isle of Man
31
Drives: '07 Z4MC
holy crap. i just realized...what on earth am i going to do about the welded in cage i have?
that liner is not going to want to come out :/
'07 MCoupe
lots of mods
      12-23-2013, 10:08 PM   #7
Nate4641
Nate4641's Avatar
Drives: '07 M Roadster
Yikes! Take lots of detailed picks for us when you figure it out though. That will help out anyone else with a cage I'm sure.
      06-20-2017, 01:21 AM   #8
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
I recon my roll bar will actually be ok, I have about 1/5th of an inch to play with. Very happy Ian was able to get it out the side door, if it would have had to go through the boot, that would have destroyed my liner.
Powered by
      07-27-2017, 06:17 PM   #9
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Pic Update pending......
Photo bucket
      07-27-2017, 09:31 PM   #10
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Photo bucket
Yeah, really hate those guys.
      07-28-2017, 09:41 PM   #11
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Updated with some pics I was able to dig up.
Unfortunately many of the originals are gone
      03-19-2018, 12:23 AM   #12
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
LOL rollbar was not fine and had to be removed to get the liner out. I also looked at various options to remove the roof, and i, going from Alex's lead found that using a Guitar string (the smalls gauge one) was very easy to .. cut.. the rood off.
i have a few pics which ill post for completeness of Ian's thread.
Choose a starting point, and with a very small gauge screw driver push the guitar string through the black goup holding the roof on. I choose the backside where the boot lid goes up to start. then attach something that you can hang on to on both sides of the wire, and then you just PULL it along. but just take it easy. i used 2 guitar strings, broke 1 half way along in one of the corners. where it kinda jammed between the bottom support and the roof support where it bolts in.
Hope that made sense, it will become clear when your doing it.
Thanks to Alex and Chris for the info/method.
Powered by
      10-29-2018, 11:46 PM   #13
AParsh335i
AParsh335i's Avatar
Drives: Z4MC / M5
Hey guys - picked up a roof from a forum member in the classifieds and planning on installing it in the next week or so. Do any of you think it would be good to use a heat gun to try to heat up the glue and then just push/pry the roof out? Also do you think fishing line could work?
2007 Monaco blue e90 BMW 335i SOLD
2011 Black E82 BMW 135i SOLD
2007 Titanium Silver E86 BMW Z4 M Coupe FOR SALE
2016 Pure Metal M5
      10-31-2018, 01:32 PM   #14
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
No to both ideas.
The bond is VERY strong.
