      09-09-2013, 03:27 PM   #1
Spedracer81
Drives: Z4MC
Front Control Arm Bushings diy?
Hello all,
After getting a quote from BMW for $850 to replace both bushings, I'd like to do it my self but am looking for a DIY guide...
I can't see it being difficult job, just like some quick info..
Any Help?
| 2008 Interlagos Blue Z4MC |
| AA Tuning | RPI Scoop | H&R Sport Springs | Sportline CS 16 CSL Wheels | Magna Flow Custom Exhaust |
      09-09-2013, 09:31 PM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
850 for FCABs, that's crazy.
- drop the structural bottom plate
- two bolts to drop the lolly pops
- a puller to pop the FCAB off of the control arm
- a press to pop the bush from the lolly ( many parts stores have loaners )
- reverse the process.
No alignment required.
      09-09-2013, 09:59 PM   #3
Spedracer81
Drives: Z4MC
Thank you..
I was just looking to get this:
http://www.turnermotorsport.com/p-19...r-m-coupe.aspx
      09-09-2013, 11:16 PM   #4
StickMon
StickMon's Avatar
Drives: 2006 MR
Originally Posted by Spedracer81 View Post
Thank you..
Good luck. They're back ordered everywhere, even Germany.
I ordered a set from getBMWparts June 27th.
No word yet on arrival.
      09-10-2013, 06:37 AM   #5
Spedracer81
Drives: Z4MC
Really? BMW said they could have the parts in 2 days, but I don't want to pay $280 for the parts..
      09-10-2013, 10:08 AM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
JM2C but I don't understand why OE?
they don't last worth a damn.
My right side was completely torn at very low miles.
The SuperFlex are far superior.
      09-10-2013, 11:20 AM   #7
dean911
Drives: '07 Z4 M Coupe
How many miles are "low miles" ?
Thanks, Greg
      09-10-2013, 11:46 AM   #8
Mirko
Mirko's Avatar
^WHS ... he installed mine
I have no issues with the SuperFlex bushings and highly recommend them as a viable replacement to OE.
      09-10-2013, 11:54 AM   #9
StickMon
StickMon's Avatar
Drives: 2006 MR
My original OEs are fine at 90k miles.
Figure if I put in a new set at 100k, I'm good for another 100k.
I wanted the full lollipop so I wouldn't have to deal with pressing out/in.
I paid $125 for the pair. Of course, I don't actually have them.
      09-10-2013, 11:55 AM   #10
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Thanks, Greg
27K miles.
The problem with OE is that with the offset, there is very little rubber on that side, so it tears.
      09-10-2013, 12:01 PM   #11
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Have you had a close look on the narrow side of the offset.?
The two sets that I have changed out were both torn in the same place.
Its not easy to see unless you examine closely.
I have one other set to change for someone else..... it will be interesting to see if he has the same issue.
      09-10-2013, 01:08 PM   #12
StickMon
StickMon's Avatar
Drives: 2006 MR
I'll give them a closer inspection this weekend, while I'm under there making sure my trans mounts aren't dissolving.
      09-10-2013, 01:49 PM   #13
Spedracer81
Drives: Z4MC
should I replace both or one at a time?
      09-10-2013, 02:02 PM   #14
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
both
