FORUMS
- 5
| 12-15-2010, 05:45 PM | #67 |
Does anyone know what the ideal width 19 inch BBS CH is for a z4mc?
I just bought a z4mc with 19 x 10 ET20 on the rear and they stick out slightly which I think is illegal in Australia. Next sizes down are 19 x 9.5 ET40 19 x 8.5 ET35 I would still like to see the dish from the edge of the wheel to the centre cap. |
| 01-04-2011, 04:45 PM | #68 | |
Front: 19 x 8.5 ET32 Rear: 19 x 9.5 ET35 ![]() ![]() ![]()
Nikki![]() |
| 01-04-2011, 05:08 PM | #69 |
///M-fanatic
Drives: '07 Z4MC, '04 325Ci Join Date: Oct 2007
My TE37's are sized:
19x8.5 fronts ET+30 w/ 225/35/19's (no idea why previous owner put 225's. Maybe for clearance issues? ) & -3* camber19x10.5 rears ET+22 w/ 275/35/19's & -2.2* camber The rears rubbed a little since I'm mildly dropped on TCK D/A's. I've since gotten the rear fenders rolled slightly, so the tires only rub on the plastic fender lining now. I don't think I'll be able to go 285's in the rear, will have to stick with 275's. But I do plan on widening the fronts to 245, that's for sure.
VF570 S/C|TIAL BOV|SetRabCooler|Brembo GT 6/4|TE37s|NT05s|3.91 Gearing|TCK D/A|RPi Induction|SS Race Mufflers/X-pipe|JVT Headers|AS SSK|Sparco Pro2000/6pt.Harness|MS FloorMounts|SE Custom Harness Bar|Tekarbon Angels|M-Tech Pedals|OE Strut Bar|RE RSMs|8000K D2S|CDV DEL|CF Roof Wrap|MB Grills|UUC TrannyMounts/ClutchStop|V1 Mount|P3C Gauge
| 01-05-2011, 03:22 AM | #70 | |
DHS
Drives: bmw x5, m3, Acura TL Join Date: Oct 2010
I did just pick up a set of ADVANs in a 18x9 +22 and 18x10 +25 setup. So I downsized a tire to 235 and went 265 rear and no issues on an E46 M3 and Z4MC. I am also running a Winter setup on my Z4M with my E9X M3 OEM wheels with a 19x8.5 +29 and 19x9.5 +22 with a 245/275 tire setup. No issues or rubbing either.
Alpine White X5
Jerez Black M3 White Diamond Pearl TL Sapphire Black Z4MC (Sold) Berlina Black NSX (Sold) Last edited by Endless619; 09-15-2011 at 10:30 PM. |
| 01-16-2011, 06:31 PM | #71 |
Drives: A///MERICAN!!! Join Date: Mar 2010
Tischer has E9x ZHP wheels for a good price
19x9 ET31 19x10 ET25 http://www.trademotion.com/partlocat...catalogid=4462 Rears too aggressive? |
| 01-16-2011, 07:13 PM | #72 |
Here are a few teaser pics of mine with 19 inch BBS-CH.
Current: BMW Z4 M Coupe - Interlagos Blue - Carbon Leather Interior - Extended Leather - Sat Nav - Heated Seats - Supersprint Exhaust - BBS CH 19's - Stubby Aerial
Sold: '07 BMW 130i, '04 VW Golf R32, '03 Reno Clio Sport |
| 01-20-2011, 03:49 PM | #74 |
Hello,
I have ordered following wheels: Front: 19 x 8,5 ET 32 Rear: 19 x 10 ET 38 The rules here in Belgium are: 1) wheels may not stick out 2) rotation proportion (hope you understand this translation) of the new rim + tire may not be less then 2% and more then 1.5% of the rotation proportion of the original rim + tire (see "omwentelingsverhouding" in http://www.tyrestretch.com/files/Tyr...or_English.xls) The only tire size options I have (because of rule 2) are: Front: 235/35/19 or 245/35/19 or 255/35/19 Rear: 265/35/19 of 285/30/19 I would prefere: Front 245/35/19 Rear: 285/30/19 Will these tire and rim setups work without rubbing? My car isn't lowered ... but maybe in the future I will lower it a bit. Thanks for your help. Yves |
| 01-24-2011, 06:02 PM | #76 |
///M-fanatic
Your fronts will clear no problem with 245/35/19's, but I wouldn't try anything wider with that size/offset wheel. The rears I would try 265/35/19's first. If that clears, then upgrade to 275's next time around.
Since you're not lowered yet, 275's might fit fine, but once you're lowered (even slightly), you'll get rubbing with 275's I'm pretty sure. I'm going off of judgment from my own personal set of wheels, which are sized 19x8.5 +30 fronts & 19x10.5 +22 rears. And I'm running 245/35/19 fronts with some rubbing on the fender well (black plastic) lining, along with 275/30/19 rears with some rubbing on the lining as well. I'm slightly lowered on coilovers, but only mild lowering. I've also got the rear fenders rolled a tiny bit as well. Still rubs on very big bumps or if I load my suspension and hit a bump in the road, etc. If I have a passenger in the car, it's also easier to rub, even though it's only slightly.
| 01-26-2011, 10:51 AM | #77 |
Hi, guys!
I'm going to place an order for a set of forged wheels. Is there any serious difference between z4 and z4m? Original set of z4m wheels fits perfectly with plenty of room. afaik, the main difference is front camber and stronger rear part of suspension. That means that I actually will have less problems with fitment (in theory ) |
| 02-02-2011, 11:41 PM | #78 |
hey all i need some friendly advise please for the rear... i plan on installing a set of eibach springs, and my main concern is the rear... i have two rear wheel options...
18x10 +38 18x10 +18 i should expect about .5 of an inch drop in the rear... Can anyone please help and comment on which of the two offsets would be the better, safer decision? thanks, all. Michael |
| 02-03-2011, 07:23 AM | #79 |
See what some other people say, but I think the +18 is a definite no; drop or no drop - will stick out way too far.
+38 might have interference on the inside. then again, just noticed you don't state what car you have either, that would help. Unless they are going on the pathy, then I have no idea what will fit ![]()
![]() |=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
| 02-04-2011, 01:41 AM | #82 | |
///M-fanatic
| 02-04-2011, 08:21 AM | #83 | |
SSGT USMC - '78 - '86
Drives: Z4 3.0si Join Date: Jul 2010
I'll be able to study for a bit with these and hopefully figure it out.
Thanks,
Bill 2007 3.0si Roadster Black/Red, sport, Piano Black F14 Forgestar's |
| 02-16-2011, 10:05 AM | #85 |
BBS Challenge for my 3.0 Z4 roadster 2006
Hello all
I ordered BBS Challenge for my Z4 3.0 2006 roadster, I ordered in 18" ( streets here are not as in US :- ) so I ordered for front - 225/40/18 8.5J ET35 and Rear 255/35/18 10J ET 35 its to replace the OEM 200 bmw wheels with 225/45/17 8J ET 46 Does anyone have that measure and does it works with no problems ? i ask for rear BBS Challenge 255/35/18 9.5J ET 35 but they can only do with 10J for the BMW Z4 with that BBS models. here is the rims I ordered ![]() its I believe the same as Mr_130i_OZ but he has I believe 19" |
| 02-16-2011, 10:10 AM | #86 |
| 02-16-2011, 08:23 PM | #87 | |
So with these wheels and tires on I was getting basically no rubbing under normal road condition but substantial rubbing up front under full compression. Good dips in the road or very hard cornering on a banked tight curve, like the really twisty mountain roads, would result in pretty good rubbing, inner fender liner, front outside edge. I recently got around to swapping my stock springs and dampners for GC/Koni yellows and Dinan springs. I expected the front to rub more, and it does, now over smaller bumps in the road but not the really small stuff. Now the rear also rubs under moderate compression. The decision is this - sell them and try something else, or down size tires. The suspension is something that I definitely want on the car and I may change it over to a coil over system (GC makes components to convert the struts to coil over). Lowering any more than the minimal drop with Dinan springs may make it rub even with 245/40 and 275/35 tires. Opinions welcomed.
| 02-17-2011, 01:27 AM | #88 |
Any one here know this guy?
That is some crazy fitment for sure and looks great. Goes to show you dont need 19's at all for these cars. Specs from Rimtuck.com FRONT REAR WHEELS WHEELS Diameter: 17 Diameter: 17 Width: 9.0 Width: 9.0 Offset: +5 Offset: +8 TIRES TIRES Manufacture: Falken Manufacture: Continental Model: 512 Model: Contisport Width: 205 Width: 215 Profile: 45 Profile: 45 ![]() ![]() ![]() ![]()
![]() EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - 206kws 12.8sec Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold |
| Bookmarks |
| Thread Tools | Search this Thread |
