      07-16-2013, 11:06 AM   #1
3002 tii
3002 tii's Avatar
2282
How Many of You Actually Rotate Tires?
For those with a square setup, do you actually rotate or bother flipping asymmetrical tires?
Follow for latest mods
      07-16-2013, 11:39 AM   #2
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
If I had a square set up with non-directional tires I would, I guess.
      07-16-2013, 10:07 PM   #3
seank
enthusiast
seank's Avatar
48
Yes, on the track car every track day. But for the z4m with square set-up, I switch inside to out side rather than front to back. This is because I have more camber in the front, and I have found that if I rotate and flip, I have less contact patch in the rear and more in the front which makes me uncomfortable.
Lesson learned: don't run more camber than you need so your tires will wear evenly from inside to outside.
      07-16-2013, 10:57 PM   #4
3002 tii
3002 tii's Avatar
2282
But inside to out assuming non-directional, correct?
      07-16-2013, 11:38 PM   #5
seank
enthusiast
seank's Avatar
48
They are directional. Moving left to right and vice versa.
      07-17-2013, 01:22 AM   #6
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
i flip fronts to back, to lazy to go to tire shop to flip left to rights
      07-17-2013, 09:36 AM   #7
a_riddler
Bimmer Noob
a_riddler's Avatar
Drives: 08 Z4MC;08 MBZ E350 4Matic
+1
left -> right, same reason, high neg camber.
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing,
AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges
      07-17-2013, 12:11 PM   #8
Kgolf31
Kgolf31's Avatar
459
Drives: 2007 Z4MC, 2012 128i
Staggered, not square set-up.
I dismounted and flipped my tires for even wear. Too much outside shoulder wear, wanted to prolong the tires past 2 seasons...if possible.
Yes it cost money. But it is either that or paying for another set of tires when I cord the outside. You need to pick your battles IMO
      07-17-2013, 01:06 PM   #9
3002 tii
3002 tii's Avatar
2282
I understand that but someone said rotate side to side after each track event.
      07-17-2013, 03:35 PM   #10
seank
enthusiast
seank's Avatar
48
Right, so you guys are not only switching left to right but flipping them inside out since they are directional? Doesn't that get $$$ quickly to take it to a tire shop to dismount, mount and rebalance each time?
Not if you don't pay full price. It's $80 which is a lot cheaper than expensive new tires.
      07-17-2013, 08:30 PM   #11
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I flip my fronts to the back when the inside edges get visibly worn from the camber up front
directional tires, so no point in dismounting and reversing
      08-05-2013, 01:44 AM   #12
Small Yellow
Track Addict
Small Yellow's Avatar
Taiwan
110
Drives: 2010 BMW M3 E92 | 2008 Z4M E86
If you know shop owner you can get it done for 40 or maybe even less if you go often enough. I get mine done for 40 (remove, mount, balance)
BMW ///M3 Coupe
Completed November 16, 2009
Received December 29,2009
      08-05-2013, 07:42 AM   #13
schwank
Drives: 06 z4 m coupe
I'd swap em left to right too, about every other event.
K&W v3, APR splitter, magnaflow axle back35% tint, stubby antenna, Jet black, and interlagos blue stock wheels, clutch delay delete, illuminated ZHP shift knob, Leather Z m shift boot, and arm rest.
      08-09-2013, 03:05 PM   #14
pal
pal's Avatar
433
Drives: Z4 M Coupe
I rotate assymetric tires left to right every few track days.
And recently had my tire shop flip front tires inside/out on directional NT-05s that were wearing out driver side outer edge.
      08-09-2013, 09:50 PM   #15
seank
enthusiast
seank's Avatar
48
Outer edge? You need more camber.
      08-19-2013, 09:08 AM   #16
pal
pal's Avatar
433
Drives: Z4 M Coupe
I know. I am running about -2.3° and that has been good for street and track.
      08-20-2013, 06:56 PM   #17
z3papa
Drives: 11 E92 M3 ZCP, 07 335i
yes -- every opportunity which means about 10 times a year.
Sold 2011.5 E92 M3 ZCP.
