06-21-2013, 06:12 PM | #1 |
636
Rep 3,124
Vanos air coupling tool
So I just got this air coupling to pressurize the Vanos when remove/replacing, and not surprisingly it doesn't fit my 1/4" industrial style quick disconnect.
It's not a 1/4" automotive or ARO either. The diameter is something between a 1/4" and 3/8". The tip on a 1/4" measures about 0.315", about 8mm. This thing is just under 0.4", about 10mm. Anybody have one of these and/or know what type of female coupling will fit? |
06-23-2013, 11:01 PM | #2 |
636
Rep 3,124
Bump.
Nobody on the East side of the pond recognizes this pneumatic coupling? Anybody know of a European heavy forum I could try? M3Forum.net was no help at all. Last edited by StickMon; 06-23-2013 at 11:09 PM.. |
06-25-2013, 10:29 AM | #3 |
Rep 296
2007 Z4MC, 1" drop H&R Springs, Evolve Tunning, Headers, K&N Filter, RPI scoop, Red top high energy coils, UUC Red Poly mounts (none bolt-through), UUC Lightweight Flywheel with Organic Clutch and a custom exhaust with just one AeroTurbine muffler.
06-25-2013, 11:29 AM | #4 |
10625
Rep 4,848
Looks like euro/din coupling.
Like this: http://www.ebay.com/itm/DRAPER-AIR-T...item35c7d2c0d0 Most used air couplings in europe are Euro/din, Orion and sometimes PCL (but there are loads others, really annoying)
06-25-2013, 12:14 PM | #6 |
Rep 296
yea that adapter looks perfect as it is a standard nipple size with that XF socket. No permenant changes are needed to any airlines or tools.
09-09-2013, 11:01 PM | #7 |
636
Rep 3,124
UPDATE!!
Thanks to bignosejim for all the answers.
This fits the BMW Vanos air adapter, and gets you to a 1/4 female NPT: McMaster 53445K19, European-Shape Hose Coupling. But it gets better. He didn't stop there. Get 6534K19 and 4936K153, screw them together, and you have a Vanos air adapter that fits a 1/4 Industrial Shape coupling for less than 12 bucks, instead of 30 bucks plus whatever couplings you may need.
