04-09-2013, 09:01 PM | #1 |
instagram 997turbotom
279
Rep 7,377
Better performance with AC on?
Floridian heat has sapped a butt dyno estimated 20hp from my car, compared to driving it in Philly. Whats odd, is that recently I've been driving it with the air conditioning on, and it feels like I have more torque.
The supercharger kit is very ambient temp sensitive with how the car feels. Its not decreasing in performance with time (heat soak), but feels stronger or weaker with as little as a 10* temperature variance. I've heard some 911 turbos run faster with the AC on, because of how the AC lines are routed. Could it hold true for the Z4M also, or am I just being crazy?
04-09-2013, 10:04 PM | #3 |
///M-fanatic
193
Rep 3,885
WTF? How does the AC have to be routed in order to actually have performance gain from using it?
We know that: 1) AC runs off of the crank, so it saps a tiny bit of power as-is when in use 2) AC generates heat with all else equal Please enlighten me on the other variable(s) |
04-09-2013, 10:10 PM | #4 |
Rep 892
The ac compressor turns off during full throttle...
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i |
04-09-2013, 11:38 PM | #6 | |
279
Rep 7,377
I've also always felt like the AC took away power, but maybe its helping the supercharger somehow. Very small chance, logically speaking, but I'll definitely try it on/off on my next dyno run
04-10-2013, 01:40 PM | #7 |
salty cowboys fan
6158
Rep 3,406
AFAIK the AC compressor is belt driven and has a clutch, which closes when you turn your AC on, otherwise the pulley is free-wheeling. I doubt the lines running the refrigerant have any cooling effect on under-hood temps.
04-10-2013, 02:19 PM | #8 |
Rep 5,328
+1
04-10-2013, 03:18 PM | #9 | |
10838
Rep 4,891
Only the lines after the evaporator might be coldish. The evaporator tries to absorb as much heat as possible though. Everything else is hot in the ac system, and judging form the size of the average condensor there's a fair amount of heat to be dissipated (and gets both under the hood and directly heats the radiator (which is usually placed behind the condensor). I think the only better performance with ac on is coming from the driver who can keep a cool head
04-10-2013, 04:16 PM | #11 | |
279
Rep 7,377
04-10-2013, 06:24 PM | #12 |
Rep 12,565
I route the AC back to the intake
04-11-2013, 09:22 PM | #14 |
Rep 704
Drives: '08 MC
05-29-2013, 07:59 PM | #15 |
Rep 46
I noticed a modest boost in highway MPG with the a/c on in 50-60 degree evening temps. Looking to repeat the experiment in 90 degree daytime heat. Also, my thermostat (gauge on dash) reads low around 180 when full warm... Maybe some correlation.
06-12-2013, 12:16 AM | #19 |
636
Rep 3,124
I notice that my exhaust note sounds a lot better with the air on.
(Because it's working harder to run the compressor) Maybe it just sounds torquier with the air on. |
06-13-2013, 03:04 PM | #20 |
Rep 296
Go to the dyno!
Maybe the added load% remaps fuel/vanos to a diffrent map?
2007 Z4MC, 1" drop H&R Springs, Evolve Tunning, Headers, K&N Filter, RPI scoop, Red top high energy coils, UUC Red Poly mounts (none bolt-through), UUC Lightweight Flywheel with Organic Clutch and a custom exhaust with just one AeroTurbine muffler.
06-15-2013, 10:02 AM | #22 |
279
Rep 7,377
thanks for the confirmation
