      04-04-2013, 10:36 AM   #1
3002 tii
3002 tii's Avatar
Drives: E85, E90, F25
Tire Pressures Uneven After Hot Laps
I start the session with even pressures, typically 32 cold all 4 and check when come back the paddock. I noticed however at the last event, both my right side tires were 2lbs higher than the 2 lefts, why is that? Is it the nature of the track, having more right handed turns and the right side tires working more?
      04-04-2013, 10:41 AM   #2
Kgolf31
Kgolf31's Avatar
361
Drives: 2007 Z4MC, 2012 128i
Sounds about right. Just the nature of the track.
Happens to me fairly often in autocross. I'll either cook the left or right front tire depending on the layout and then I'll start running different pressures on the left and right side
      04-04-2013, 10:57 AM   #3
a_riddler
Bimmer Noob
a_riddler's Avatar
Drives: 08 Z4MC;08 MBZ E350 4Matic
+1, very common autox-ing.
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing,
AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges
      04-04-2013, 12:36 PM   #4
gmd2003
gmd2003's Avatar
272
A given track can have significantly more turns in one direction versus another. At my home track Roebling road it kills the left side. My temps are 4 degrees hotter on the left F/R despite using Nitrogen!! Thats why its key to take regular tire temps, and check pressures during the course of your day. Once you know what to expect you can plan accordingly. For instance I start off at 28PSI on the left and 30 PSI with Nitrogen on the right now at this track.
      04-09-2013, 07:35 PM   #5
kklin
Drives: BMW Z4 M Coupe
Most road race courses are clockwise, so I'm surprised it isn't your left side pressures that are higher.
      08-05-2013, 02:37 PM   #6
Racer20
Drives: F80 M3, 228i THP, E46 ZHP
On my track car (Mini Cooper S with Star Specs) I shoot for 39psi hot at all 4 corners, and adjust after each session to keep it there.
