Reply
      03-04-2013, 05:17 AM   #1
FreeParking
Drives: 07 z4///m coupe, 99 540i-6 /M
Anyone U-Haul their Mc?
Thinking about purchasing smellyborrelli's Z4Mc. And if the drive and my inspection goes well I'd be bringing it home. No Problem, however, it is 600 mi or so.
I'd either 'tow' it with a tow dolly, or put it on a U-Haul trailer...Any advice? has anyone moved their car themselves? Yes, I realize I could just drive...I've got this thing about not driving my BMW's until April in that I live about 50 miles south of Ann Arbor Mi and I don't want rust on any of my cars...
Thanks in advance...
FreeParking is offline
      03-04-2013, 09:06 AM   #2
David70
Drives: '06 Audi A3, '06 Z4M Coupe
To me, if you are trying to avoid salt and bad weather, the dolly doesn't seem like it would make much of a difference (assuming two wheel dolly?). The open trailer would be better and the enclosed trailer the best. Even with the open trailer, if you run into snow I think the surface of the car will be covered with salt.
David70 is offline   United_States
      03-04-2013, 09:21 AM   #3
FreeParking
Thx
I assume clear roads since its not in the forecast. My question may have been unclear. Has anyone transported their own vehicle using either method? As far as hooking it up and the actual drive. Since the roads will most likely be clear in the unlikely event of rain/snow I could cover it (on the trailer) and its only an 8 hr ride.
FreeParking is offline   Reply With Quote
      03-04-2013, 09:47 AM   #4
Geauxkart
Geauxkart's Avatar
Drives: 2007 Z4 M Coupe Sepang
Cover it and drive at 50MPH??
The flapping of the cover will do far more damage than the salt or rain will!
Get a quote for it to be transported for you, probably close to the cost of the trailer rental - not to mention your time. It's going to be a 12 hour ride if it is 600 miles, you aren't going 75 MPH with that trailer... And not even close with a tow dolly. (Which is not a good idea for a RWD car anyhow).
I had mine moved by Gran Turismo auto transport, enclosed, about 3x the distance, and it was around $1000.
I'd do it again with them if I ever need to.
Geauxkart is offline   Reply With Quote
      03-04-2013, 10:11 AM   #5
elwesso
elwesso's Avatar
Drives: Z4 M Coupe
I think if you really have only have 2 options, if driving the car is not an option.
1. Have it transported for you on a flat bed.
2. Rent a flat bed trailer from U-Haul.
I have never personally done it with a dolly, but I know some people have said that towing a car with a dolly is not fun times, especially on long distances. I know everyone that I've talked to says the flatbed is the way to go, it's basically the same as pulling a boat or something like that.
Trailering it is probably cheaper too.. If say you and a friend went down to pick up the car, you'd be paying double on the way back.
Get yourself some good ratchet straps and drive away! 600 miles isn't that bad, easy day trip.
- Wes
1994 Infiniti Q45- First 5-speed swapped Q45.
2007 BMW M Coupe
elwesso is offline   Reply With Quote
      03-04-2013, 10:59 AM   #6
ricanbandit
ricanbandit's Avatar
Drives: 2008 M Roadster
I tried to load my Z4MR onto a uhaul trailer (car carrier not the dolly) and it would not work. the fangs get in the way and I was not able to to tie down the wheels properly, so I was not able to do it that way. I did notice on my way down that the budget car carriers are not setup in the same way and did seem to allow for the car to go all the way to the front so that the wheel could be tied down successfully.
///M Roadster: Stromung Exhaust, Stubby, BMW Performance Shift Knob, RPI scoop, TSW Nurburgring's, Total DeBadge
ricanbandit is offline   Reply With Quote
      03-04-2013, 12:11 PM   #7
Geauxkart
Geauxkart's Avatar
Also, bring some ramps for the rear wheels of the truck - in case you have clearance issues on the ramp. Raising the truck will lower the ramp significantly, and flatten the transition between the ramp and the trailer deck.
I have to do this with 2 of my cars to get them in my trailer.
      03-04-2013, 05:26 PM   #8
FreeParking
Thank you
Lots of good stuff
      03-04-2013, 05:45 PM   #9
Shipkiller
Shipkiller's Avatar
Drives: 2008 Z4MC & 2003 Z4 Roadster
If you are going to do this yourself, then:
A dolly is specifically NOT recommended by BMW and is stated "use at your own risk and possible damage to the vehicle may result".
If using a car carrier, do NOT attempt to tie down the car using the wheels. The approved and accepted method is to use four T-Hooks. You pull the four plastic jackpads off (they are designed to come off) and insert the T-Hooks.
I keep two T-Hooks in the car at all times for emergencies.
Shipkiller is offline   United_States
      03-04-2013, 06:42 PM   #10
gghg
Drives: 06 M Coupe
I tralered my MC last summer. I rented a truck and car trailer from U haul. No problem loading the car the ramps were fine, the problem was I couldn't get the car forward enough on the trail to get the straps on. The issue was that the front of the car sits to low for the trailer, it interferes with the trailer stops. The fix was to load the car on backwards, no problems. The only issue was getting out of the car because of the trailer fenders.
gghg is offline   Reply With Quote
      03-06-2013, 02:43 PM   #11
EenyBear
Accidentally in BMW
EenyBear's Avatar
Drives: Z4MC & R1200S
Assuming driving is not an option, hiring a covered transport company is the next best (and possibly best) option. Insurance etc. is included and the cost will be balanced by peace of mind. No fuss, no muss, no personal responsibility if something goes wrong. Even an uncovered transport will work OK but have the shipper (or smellyborrelli) wrap the front and rear and doors... just like the new cars. Just ask that it be put on the top level. Don't worry about rain as the car is waterproof.
Regarding shipping cost, the price from "major city" to "major city" is generally much cheaper than door to door. Again, not sure where you are, but having the car dropped at a dealer (or friend or forum pal's home) in a major city nearby could save several hundred$. Experience.
I realize it's still winter in some parts of the country, but the option of driving home in your new car is the most appealing to me - assuming the clear roads you mentioned. The time is the same and the cost is probably less... and the enjoyment would be definitely more. But I'm sure you have your reasons.
Word of caution... no matter who puts it on the trailer/flat deck/etc. have someone knowledgeable (like smellyborelli) standing by to shout out if the fangs get close to touching at any point in the loading process. Without a doubt, they are the most vulnerable part of the car.
CONGRATULATIONS!
EenyBear is offline   Canada
      03-06-2013, 02:48 PM   #12
elwesso
elwesso's Avatar
Drives: Z4 M Coupe
Good info, is there any way you could elaborate on this, or what I might search to find this out?
- Wes
2007 BMW M Coupe
      03-06-2013, 04:01 PM   #13
Shipkiller
Shipkiller's Avatar
This is only one source but you now get the idea:
http://www.awdirect.com/tie-down-hoo.../?ICID=FP1A3TA
      03-06-2013, 04:33 PM   #14
EenyBear
Accidentally in BMW
EenyBear's Avatar
I'm always learning something from Shipkiller...
Here's a version with an extra ring (for another couple of bucks).
Ordering mine. Great advice.
http://www.summitracing.com/parts/mtd-340003
      03-07-2013, 01:11 PM   #15
FreeParking
thx
I am of the idea driving may be best...but I am ordering a set of these, actually all 4
      03-07-2013, 04:57 PM   #16
RandysV10
MPOWERD
RandysV10's Avatar
Drives: 2010 M6
2006 Z4M  [0.00]
2010 BMW M6  [0.00]
If you end up getting a trailer, get it strapped down good and have the car in neutral when towing you don't want to mess up your gearbox.
2010 Dinan M6 Coupe--2006 Z4MC--1994 E36/M3 Track Prepped
BMWCCA #442445
YouTube Channel: http://www.youtube.com/user/Randy23185
RandysV10 is offline   Reply With Quote
      03-07-2013, 05:24 PM   #17
SD Z4MR
(formerly SD 335is)
SD Z4MR's Avatar
Drives: '06 Z4 M Rdstr | '11 335is E92
I ordered these same tie-down hooks and keep a couple in my car. The only problem with AW Direct is that they send me a catalog about every two months that's the size of a small phonebook and would only be of interest to someone in the towing industry. The "Contact Us" form on their website returns an error, but I finally found an e-mail address and I asked them to stop sending me catalogs.
They also sent a 1:87 scale model of a tow truck with my order which my nephew enjoys!
Mine: 2006 Z4 Roadster | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Premium | Navigation | Heated Seats | iPod Adapter | Purchased 7/19/12
Hers: 2011 335is Coupe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | Premium | Convenience | Heated Seats | Navigation | Harmon Kardon | iPod/USB | European Delivery 5/12/11
SD Z4MR is offline   United_States
      03-07-2013, 05:29 PM   #18
SD Z4MR
(formerly SD 335is)
SD Z4MR's Avatar
Note for anyone removing the jackpads, they work like giant plastic pop rivets with a plastic center post. When you re-install them, remove the plastic center post first, put the jackpad into place and then whack it so that the plastic fingers are inside the hole, then insert the center post and push it in until it's flush.
      03-08-2013, 10:14 PM   #19
FreeParking
Decided
To drive her home...there is always soap and water to wash her up
      03-09-2013, 07:38 AM   #20
Shipkiller
Shipkiller's Avatar
If the weather cooperates, then it will be a great drive home.
I flew to TX to get mine and it was a two day drive home just about this time of the year.
Reply
Forum Jump
