Reply
      02-26-2013, 09:43 PM   #1
STIHLBOLTS
STIHLBOLTS's Avatar
Drives: 08 Z4M Roadster
Z4 M - RPMS Went Crazy
Driving home Saturday the car started acting nuts at shut down and start up. Bouncing rpm=500-700 and then not staying running. Service Engine Light came on.
Indy shop says vvt error and other's but they conflict with each other, did my vanos go out?
2008 - Z4MR BMWCCA / ZSCCA Member
STIHLBOLTS is offline   United_States
      02-26-2013, 10:21 PM   #2
DRedman45
DRedman45's Avatar
Drives: 07 e86 //M coupe
vanos is definitely a strong possibility....also similar type symptoms as dead coil packs...more info on the codes would be helpful though
DRedman45 is offline   Reply With Quote
      02-27-2013, 09:19 AM   #3
STIHLBOLTS
STIHLBOLTS's Avatar
Shop thinks it the IAC.
I'll see if he will tell me the codes.
      03-02-2013, 02:35 PM   #4
STIHLBOLTS
STIHLBOLTS's Avatar
It was not the IAC after he replaced it.
      03-02-2013, 03:26 PM   #5
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
were you able to hook it up to a bmw code reader?
The Raspinator
SCHMOUPE is online now   United_States
      03-02-2013, 03:46 PM   #6
STIHLBOLTS
STIHLBOLTS's Avatar
Yea, I hooked it up to the one I have, but I did not down load the codes. Car is at Indy shop right now.
      03-04-2013, 07:05 PM   #7
STIHLBOLTS
STIHLBOLTS's Avatar
It was the bearing on the intake hub. I don't know how you can check it to prevent that from happening. It never made a sound, even when the mechanic got in in the shop and was testing. He found the one piece that broke that sealed it in. But the whole unit has to be replaced.
So fellow M owners, keep a eye out.
      03-04-2013, 08:31 PM   #8
antennahead
antennahead's Avatar
Drives: 2007 Z4MR silver grey
Sorry to hear this. How many miles are on your car now?
John
antennahead is offline   United_States
      03-04-2013, 08:45 PM   #9
STIHLBOLTS
STIHLBOLTS's Avatar
Only 45k.
      03-04-2013, 09:52 PM   #10
antennahead
Originally Posted by STIHLBOLTS View Post
Only 45k.
Do you track your car, or a DD only?
      03-04-2013, 10:14 PM   #11
STIHLBOLTS
STIHLBOLTS's Avatar
My baby is a garage queen. You are not safe just because you don't track your car. It does not make a difference.
      03-04-2013, 11:25 PM   #12
antennahead
I was afraid this was going to be your answer
      03-13-2013, 05:29 PM   #13
STIHLBOLTS
STIHLBOLTS's Avatar
https://www.facebook.com/media/set/?...2794429&type=1
I posted on Facebook in the ZSCCA all the pictures of my Vanos. The car is back together and I can tell at least a 30 percent drop in the noise. Maybe because it's I have not been it in a while, in either case it runs like a top now. I can certainly tell the difference in the performance.
And yes, it was an arm and two legs this time. $3800.00 clams to get it fixed.
      03-13-2013, 10:33 PM   #14
RobMCoupe
RobMCoupe's Avatar
Drives: 2007 Z4 M Coupe
This is the first time I seen a post bearing failure on vanos. Wonder if caused by oil starvation.
RobMCoupe is offline   Reply With Quote
Reply
Forum Jump
