Reply
      02-08-2013, 01:25 AM   #1
Barryb97
Drives: 2006 M coupe
Camber shims and Toe
After installing camber shim washers on the front of my Z4 M coupe. I measured my camber at about -2.9 degrees (iPhone). Sounds about right. I expected since I added washers that I would have more toe-in. When I measure with my new Longacres toe plates I get about .5 degrees toe-out. Does that sound right? For some reason I thought by installing the washers I would make more toe-in.
CDV delete, clutch stop, strut bar, SS brake lines, radiator hole cover, brake duct stop removal, Gunmetal M3 reps, RAD wheel locks, M strut caps, roundel under hood, Intravee II ipod adapter, Homelink garage opener, air bag sticker delete, first aid storage under seats, Bumper plugs keyhole cover, painted reflectors, Headlight washer disable, Mstache front lip, Autosolutions SSK, Leather Z arm rest, Stromung exhaust, RPI scoop…
Barryb97 is offline   United_States
      02-08-2013, 02:18 AM   #2
Finnegan
Finnegan's Avatar
Drives: Sapphire Black/Black Z4Mc
Yes, sounds right. More negative camber means more toe-out.
Shoot for zero toe with that much negative camber, unless you want to chew up the tires. That is tell out is nice for use on the track, but I wouldn't run it on the street.
2007 Sapphire Black Z4M / Apex EC7s / Eisenmann Exhaust / Euro Headers/Cat / Aero Sideskirts / DIY Stubby / Ultimate Pedals / AS SSK / RB Rotors / Other Stuff #1047
Finnegan is offline   United_States
      02-08-2013, 05:26 PM   #3
seank
enthusiast
seank's Avatar
Sounds right. WHS
seank is offline   Reply With Quote
      02-09-2013, 12:21 AM   #4
aerobod
Car Geek
aerobod's Avatar
Drives: E85 M-Roadster, E82 135i
As the lower control arm (LCA) attaches to the bottom of the kingpin, adding the washers between the strut and the kingpin effectively causes the top of the kingpin to move inwards (intuitively you would think the bottom of the kingpin would move outwards, but this is not the case). Thus the toe-out will increase when the washers are added as the track rod end attaches to the kingpin above the LCA ball joint.
aerobod is offline   Canada
Reply
Forum Jump
