Reply
      02-06-2013, 02:30 AM   #1
Jumbosock
Jumbosock's Avatar
Drives: 2007 M coupe
DIY rewiring Post Cat O2 sensors to Euro location
This is how I rerouted the post cat O2 sensors for my euro setup. Just wanted to post videos to help others who have never done it.
Sorry about the volume on part of this last video.
CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights
Jumbosock is offline
      02-06-2013, 03:02 AM   #2
beta
Drives: 2006 M Roadster
Great video, thanks for posting.
I roughly did the same thing, then covered the wiring in cloth tape so it would look clean. See my post here for a picture of the taped up wiring.
This will be really useful for those looking to do this mod.
beta is offline   Reply With Quote
      03-05-2013, 05:20 PM   #3
bmwschnell
Drives: Z4M coupe
Great video. I'd been wondering how you do this for a while now, and this really helps. Have you done the third video showing the connection of the o2 sensors themselves? Will the wires reach all the way back? I'm interested in seeing how you mount the wires to the underside of the car.
Beta, I saw you pictures too and they look really nice. You said that the wiring isn't long enough to to reach. What did you do to make them long enough? How did you add more length? THANKS!
bmwschnell is offline   United_States
      03-05-2013, 07:16 PM   #4
Geauxkart
Geauxkart's Avatar
Drives: 2007 Z4 M Coupe Sepang
There are clips under the heat shield to route the wires, I did not have to extend mine.
It's been 6 mos or so and no O2 codes.
Geauxkart is offline   Reply With Quote
      03-05-2013, 08:10 PM   #5
beta
Almost exactly what he did in the video. Cut into the conduit somewhat to gain an extra 10cm (less than in the video), then wrapped it with bmw cloth tape so it looks perfect.
Mine didn't reach without extending. I do have them clipped in the stock locations. See my sig for pictures.
      03-05-2013, 08:29 PM   #6
Geauxkart
Geauxkart's Avatar
I changed the factory routing a bit - on the lower part of the engine - where it transitions to the body, and it will work - and appears safe from damage / engine movement.
      03-05-2013, 08:50 PM   #7
bmwschnell
Drives: Z4M coupe
Did either of you have to extend the EGT wire too, or was it long enough to reach the new location?
      03-05-2013, 09:40 PM   #8
Geauxkart
Geauxkart's Avatar
Fine on the egt as well, no extension.
      03-06-2013, 10:02 AM   #9
bmwschnell
Drives: Z4M coupe
Ok great! So last question. Once you unwrapped the sensor wires from the conduit, what did you use to cover them back up? Regular electrical tape, or something weatherproof? What type of clips did you have to get to clip them to the underside of the car?
Thanks guys! I'm looking to do this, and I want to make sure I do it right.
      03-06-2013, 11:32 AM   #10
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
So here is what you shouldnt do! Don't extend them by cutting into them. I did that and I get a pending fault for the heater circuit. I will be tearing the car up in a few weeks and replacing that O2 sensor! It is technically long enough but you have to take the heatshields off. I was too lazy to do that and now I am kicking myself
The Raspinator
SCHMOUPE is offline   United_States
      03-06-2013, 12:00 PM   #11
bmwschnell
Drives: Z4M coupe
By cutting into them, I'm assuming you mean actually cutting the wires themselves and not cutting into the conduit as shown in the video?
      03-06-2013, 12:12 PM   #12
SCHMOUPE
SCHMOUPE's Avatar
Correct, cutting the wire and soldering it longer. Others have had no issues by doing so and the fact that I am getting a circuit heater issue makes me think that I flip flopped the two heater wires. Could be an easy fix however I am planning on replacing the entire sensor wire
The Raspinator
      03-06-2013, 01:04 PM   #13
inTgr8r
inTgr8r's Avatar
Drives: 07 M Coupe
definitely plan to keep mine in one piece.
Alpinweiss '07 M Coupe •Eisenmann Sport-Ceramic Black•Diablo-X•Fabspeed Headers•VRS Hyper-Narrow rear wing•Autosolutions SSK•APR splitter•Tekarbon headlights•StrongStrut STB•KW Clubsport•Poly FCAB/RTAB•Volk Racing G2•Direzza ZII•Stoptech BBK c/w Cool Carbon pads
inTgr8r is offline   Canada
      03-06-2013, 01:52 PM   #14
beta
BMW electrical cloth tape 61136902588
Although ECS shows that part as discontinued and suggests 61136902588
http://www.ecstuning.com/Search/Tape/ES2081139/
Interestingly tischer shows it at $1 which seems wrong, while ECS has it for 27 bucks which seems high but in the ballpark.
      03-06-2013, 03:08 PM   #15
bmwschnell
Drives: Z4M coupe
Thanks guys! I think I have everything I need now. Just waiting to find the right set of headers and cat setup!
      03-07-2013, 10:58 AM   #16
GriffBrew
Talk to Donovan
GriffBrew is offline   United_States
      03-07-2013, 12:03 PM   #17
bmwschnell
Drives: Z4M coupe
Originally Posted by GriffBrew View Post
Talk to Donovan
Thanks! I'm in the process of it now
      03-07-2013, 07:31 PM   #18
Jumbosock
Jumbosock's Avatar
Yes I did make a third and final video. I just uploaded it. The bank two o2 sensor wire is JUST long enough. It has just enough slack for me to be comfortable... it's not pulling anywhere and has a little give... yet there's not an inch more to spare.
Jumbosock is offline   Reply With Quote
      03-08-2013, 09:29 AM   #19
bmwschnell
Drives: Z4M coupe
Great video jumosock! I've been looking all over. I know you can buy o2 bungs from Turner, but where can you buy an EGT bung to weld into the stock s pipe?
      03-09-2013, 11:46 AM   #20
bmwschnell
Drives: Z4M coupe
I've watched your video and I have most of the parts ready to do the reroute. I've looked everywhere for those clips you used to attach the o2 wires to the heat shield. 3 different parts stores didn't have them. Do you know where I can find them?
      03-09-2013, 01:55 PM   #21
beta
http://www.zpost.com/forums/showthread.php?t=813428
      04-07-2013, 01:20 PM   #22
donovan
donovan's Avatar
Drives: E92 m3 AW, light package
Very interesting... for the M3 the wires unravel.
e46 m3 Black
To many mods
donovan is offline   Germany
Reply
Forum Jump
