Reply
      02-02-2013, 05:01 PM   #1
drbvac
drbvac's Avatar
Drives: 2006 BMW M COUPE
RIGHT WIRES - For Boost Gauge on Dash
Red and Grey - dimmer 12 v+ = Red for Gauge
Green with Blue stripe - 12v + when car on start and run = Green for gauge
Brown - ground = connected to Black wire for gauge
Placed wires around bared area of above - checked with Voltmeter - soldered and wrapped with tape - go to connectors.
On firewall to the passenger side of car near where steering column goes through there is a 2" opening with nothing through it but there is a rubber cover you can punch a hole in for the hose to the gauge.
From inside the car through the gauge mount you can feed the hose out through taped to a coat hanger, feed it through the rubber seal and put it back in place.
Gauge should be here first of the week then I get to cut holes !
2006 M COUPE - one of 38 Imola Red produced for NA that year, ESS 455 Supercharger
drbvac is offline   Canada
Reply
Forum Jump
