02-02-2013, 01:38 PM | #1 |
Rep 832
Adjusting hood
After reading a previous thread about the buffer stops and some saying it tightened up their rattling hoods, I installed two new ones (mine were broken anyway) but found they did not really tighten up the hood. Then I looked at the U (or O if you will) shaped "hooks" on the underside of the hood that catch onto the two latches in the engine compartment to hold the hood down.
I removed the plastic screws holding down the black plastic cover over these "hooks" and found that the hooks could be screwed in or out. I screwed them in a full turn then replaced the black covers and tried the hood again. Voila! Tight hood. Many may already know this trick but thought I would share for those that don't. You can experiment by half turns to get the perfect height for the hood when closed to match the bumper. You still may need to screw the buffer stops in or out slightly to adjust the tension on the hood upwards to make it all tight when closed. |
02-02-2013, 04:37 PM | #2 |
#dubspec
6317
Rep 5,200
nice. thanks for the heads up
02-02-2013, 06:31 PM | #3 |
Rep 987
I've been trying to make mine fit right. I'll try this out!!
CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights |
02-03-2013, 09:39 AM | #4 |
Rep 832
I should also add, when you take out the screws holding the O hooks on, be careful as they are the plastic fasteners that are all over our car. The ones that you push in then when you screw in, the tabs spread on the backside. If you unscrew it all the way and it falls, it may be lost forever. Just back it out but leave in then pull out on the whole plastic bracket.
02-03-2013, 04:54 PM | #6 |
///Multiple
2992
Rep 4,243
Is anyone with a loose hood missing their rubber bump stops? There is one on either side of the hood about halfway between the front and back, just forward of where the hood strut mounts. P/N is 51237116856, #7 in this diagram:
(click for link) I think that they're supposed to line up with this "sticker" mounted on the inside edge of the fender next to the strut tower, but both of mine came off while drying the car and don't know where they were originally, but this looked like the most likely position: I know that without these bump stops the hood will rattle.
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 Last edited by SD ///M4; 04-04-2013 at 11:14 AM.. Reason: fixed incorrect part number |
04-04-2013, 02:39 AM | #8 |
Rep 36
I have done google searches, but can only find one spot that sells the bump stops. I am missing the one on the passenger side and would love to order new ones.
Does anyone know who may sell these bump stops, Number 7 in the diagram; P/N 51237116856? Thank you |
04-04-2013, 06:13 AM | #9 | |
Rep 832
08-19-2015, 02:31 PM | #11 |
Most roads are too short and too straight
Rep 66
Drives: 2007 M Coupe - Premium Package
Just ordered 2 bumpers from the dealer .... never knew I needed them until I came across this link looking for a Buffer Stop with Ejector ... got 2 of those ordered also...
2010 Honda Pilot Touring, 2013 328i xDrive Luxury Edition, 2007 M Coupe
