      02-01-2013, 03:27 PM   #1
dean911
Drives: '07 Z4 M Coupe
Z4MC oil leak
'07 M Coupe with 26K on the clock. Stored for the winter but that is giving me time to nit pick. Read the thread about lose oil pan bolts and mine were fine but there was some oil residue along the gasket and on the inside of the bottom tray. Looking for the source I found this. The oil looks to be coming from under the front of the head. Vanos? Thoughts?
The photos are looking down at the motor towards the front from the passenger side and the mirror is looking up at the head. Valve cover gasket is dry.
      02-01-2013, 03:40 PM   #2
Geauxkart
Geauxkart's Avatar
13
Drives: 2007 Z4 M Coupe Sepang
Sell it. Now.
      02-01-2013, 03:48 PM   #3
elwesso
elwesso's Avatar
25
Drives: Z4 M Coupe
My guess would be the valve cover gaskets. Have you had a valve adjustment yet? If not, you'll be replacing the seals when you get the valves adjusted.
- Wes
2007 BMW M Coupe
2016 VW GTI
      02-01-2013, 04:06 PM   #4
dean911
Geauxkart, It is just a leak. The car is stunning and runs great. I have owned 70's vintage Porsches with split magnesium cases for over 17 years. This is just a flesh wound. Just looking for someone with some history along these lines.
Elwesso, the valve cover gasket is dry as a bone. Checked it. This is at the joint of the head and block. I am guessing a vanos sub assembly or something. Have never taken one of these apart yet.
Greg
      02-01-2013, 04:53 PM   #5
RobMCoupe
RobMCoupe's Avatar
60
It might be timing chain tensioner and/or seal. I noticed oil leak when it was in Indy shop. Dealer confirmed and performed the work under warranty.
      02-01-2013, 05:13 PM   #6
Geauxkart
Geauxkart's Avatar
13
I was hoping my sarcasm was obvious...
      02-01-2013, 05:26 PM   #7
dean911
Sorry Geauxkart.
Sometimes I amaze myself at how numb I am to the obvious.
Greg
      02-01-2013, 05:27 PM   #8
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
Do you think you need to replace the vanos sealing flange?
http://www.ecstuning.com/BMW-E46-M3-...nos/ES1892456/
CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights
      02-01-2013, 05:33 PM   #9
dean911
Actually I just got a responce from Brett at Koala Motorsports. Great local shop. He suggested it might be a bolt behind the thermostat that retains a timing chain rail. Seems to be a known leak on the S54. I will find out in March when she hits the streets and Brett gives her the once over.
Greg
      02-01-2013, 05:46 PM   #10
Jumbosock
Jumbosock's Avatar
76
This is my second S54 and it seems there is always some small leak somewhere. I'm happy that my oil pan is no longer leaking. When you get it fixed let us know.
      02-01-2013, 06:13 PM   #11
dean911
Figures doesn't it? My Dinal Z3 is flawless, 11 years old with 86,000 miles on it and tight as a drum. Finally replaced an old Porsche 911 for the M Coupe and ...leaking oil? Really?
Oh well, The ride home in November from the dealer in Chicago told me all I need to know, and that is that this car and I will have a long life together.
Greg
      02-04-2013, 10:25 AM   #12
bluecobra
Drives: 2006 Z4M Coupe
If you decide to repair it, please let us know what the cause was.
      02-07-2013, 12:35 PM   #13
polar
polar's Avatar
Sweden
53
Drives: Z4MC07
Hi!
I had that leak to and BMW pointed at the vanos gasket (the one against the block). They replaced that, and some o-rings for the regulating valve in behind there.
The front and belly of the engine was marinated whith oil and guck, but it didnt leak so much it would drip. And it wasnt visible from above as you say, nor on the dip stick or from under.
It was over a year ago I had it repaired and I really hope its leak free now. I've cleaned the engine twice (from under and above) since the repair and both times I've notised a small amount of oil that looked new/amber. Seems like it originates from the chain tensioning bolt area. And it's also following the head gasket around the front of the engine to a point just above the 2nd header pipe. I will have that checked in the spring. Hopefully its just lingering oil from last time, there are lots of places for oil to hide, and it hides well.
perdidit in spatio
18" Arc-8 - Michelin Cup2 - KW V3 - GC camberplates - RE trans mounts - VT engine mounts - Vorshlag RTAB shims - RPi - stubby - CDV del
      02-09-2013, 05:08 AM   #14
BMW Maniac
Drives: Former Z4M coupe owner
Notorious for leaks, passenger side of the engine, near the transmission is a pressure valve with a faulty o-ring....I just replaced mine....I think it is called a constant pressure valve
1999 /// M3 Convertible Techno Violet
      02-09-2013, 07:30 AM   #15
Shipkiller
Shipkiller's Avatar
Drives: Me
dean911,
In that area, there are some possible's.. you have a weep from the high pressure side of the Vano's Accumulator (1850psi) and/or associated piping, Vano's body to block gasket failure or one/both of the two nuts that fasten the exhaust gas recirculation valve (no. eight) to the head is loose.
This leak is too far forward on the engine for it to be the CPV valve.
      02-09-2013, 05:09 PM   #16
O-cha
O-cha's Avatar
218
Drives: Mcoupe
Originally Posted by Geauxkart View Post
Sell it. Now.
No, that's the back., this is the front.
OP, thanks for at least tryign with a picture rather than a description, but you still cannot get a conclusive answer.
Spray the area off with brake clean and recheck after a SHORT interval. Most of the time it is impossible to know where the leak is coming from with such a long interval of leaking. Much easier when you see the first little bits coming out.
      04-02-2014, 02:13 PM   #17
evel karnievel
braaap
evel karnievel's Avatar
Germany
44
Drives: Z4M QP
Can You fix the leak?
      04-02-2014, 11:27 PM   #18
Clearancediver
Drives: 2004 Z4
I had the same leak. At the point where the Vanos assembly joins the block, the joint/seam is 90 degrees to the "line" of the valve gasket...Put a small blob of sealant at the top and bottom "joint/seams" when replacing the valve gasket. The small smear/blob fills in this small "joint" (block/Vanos gasket/Vanos assembly) preventing a leak.
Think about it for a moment and the reason why it would leak here is readily apparent. If you look in the TIS it should show also you the procedure/diagram of where the other blobs of sealant are required to ensure the gasket remains leak free.
It's dead easy to replace this gasket.. And inexpensive as well. Took me little more than an hour start to finish...but I'd had the valve cover off before and was familiar with what needed to be removed to do so.
Sent from my smart phone...
      04-02-2014, 11:34 PM   #19
StickMon
StickMon's Avatar
Drives: 2006 MR
If you've had camshaft bolt or Vanos work done, suspect the gasket between the Vanos and head. It's crushable metal, so it has to be replaced any time the Vanos is off.
The "mechanic" that did my Vanos bolts didn't replace the gasket, so I had oil dribbling down the front of my block until I did my own Vanos work and replaced the gasket.
      04-03-2014, 12:13 AM   #20
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
is it this leak? pretty common on s54 apparently.
http://www.m3forum.net/m3forum/showthread.php?t=358941
      04-03-2014, 09:33 AM   #21
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
No...as "O-cha" had indicated above, if it was the CPV, then it would be toward the rear of the engine, not front.
