      08-23-2007, 09:11 AM   #1
BlackSapphireZ
Z
Drives: 128 Vert Sport
Send a message via AIM to BlackSapphireZ
Steering Wheel Removal
before you begin, make sure you have a valid reason to do this...and only reason would be to install an M steering wheel also unplug the battery for a good amount of time. I left it for 5 minutes, others may do it for 30.
oh yea and don't sue me if you screw up. i'm not responsible for your mistake!
*it is possible for you to install any 3 series airbag/steering wheel combo if you like. Also the X series I believe fits as well*
moving on...
1)find the little holes by 10 and 2 o' clock position behind the steering wheel it self
2)Insert small and long screw driver into the hole. and you have to push the bar towards the center. it's really hard to find(was for me at least)
3)Airbag will "pop" out and hang..it's okay don't freak out. and start to unplug the wires. when unplugging the wires from the airbag, use a very small flat head for the connector...you wont be able to use your hands for that more than likely. Also if you have those black connectors in the steering column, it means you may add steering wheel controls(if i remember correctly)
4)take off the center nut which is pictured above, and steering wheel should come straight out. Make sure when you are RE installing, line up the notches on the wheel and the column.
      08-23-2007, 11:13 AM   #2
Jaydon Fabulous
Drives: 2007 z4 3.0si coupe
I'm so jealous. Great write up. Did you find a good deal on the wheel? How much does it boost your enjoyment level of driving? I want one so bad, but i can't justify spending $900.
      08-23-2007, 12:43 PM   #3
BlackSapphireZ
Z
boosts the enjoyment of driving by like 100000000!!!!
so much thicker it's just bad ass
      09-01-2007, 06:21 PM   #4
fatlaces
Drives: BMW Z4 2003 3.0i
great write up!
one question; why do you hafto unplug the battery ? what will happen if you dont ?
      09-01-2007, 06:37 PM   #5
JC5
JC5's Avatar
Drives: 2004 Z4 3.0, 2003 VFE 530
2003 z4 3.0  [0.00]
2003 z4 3.0  [0.00]
I've seen his istall in person and it is SWWEEETTTTT!!!!
      09-04-2007, 09:02 PM   #6
BlackSapphireZ
Z
Originally Posted by fatlaces View Post
great write up!
i dunno u might disable the airbag, blow the airbag, or both lol don't want to find out!
2003 Z4 2.5i Sport
miss this car
      09-05-2007, 08:16 PM   #7
155MPH
Z4um Refugee
155MPH's Avatar
Drives: Audi
what is wrong with the new wheel? It looks like it has a couple of defective dents in the top center of the wheel.
2006 ///M
Roadster Titanium Silver / Black, Carbon Leather Interior Trim, Heated Seats, Premium Package, ZHP,3" Stubby,Stromung Exhaust 2006 Porsche 911 Black/Black
      09-06-2007, 07:46 AM   #8
epbrown
epbrown's Avatar
great write up!
If you don't unplug the battery, you'll get an airbag error code and you have to take it in to the dealer to clear those.
      01-08-2009, 07:40 PM   #9
pechs2k
Drives:
i called BMW austalia today and they mentioned to me that in order to complete a steering wheel change i need to replace the steering wheel itself and the airbag module.
looks like you just replaced your steering wheel and looks great and props to your work, but are you sure the airbag is ok?
      02-02-2009, 01:35 AM   #10
reRESERVEDFX
(oO (||||) (||||) Oo)
reRESERVEDFX's Avatar
Drives: 06 BMW Z4 3.0i 03 BMW M5 DINAN
Send a message via AIM to reRESERVEDFX Send a message via Yahoo to reRESERVEDFX Send a message via Skype™ to reRESERVEDFX
The only way to find out is to hit something... hard
No, the airbag will be fine. If it wasn't, the car would shoot out an error code right away.
2006 Porsche 911 C4S Black/Black 6MT/Sport Chrono/Extended Leather/GT2 bucket seats/Turbo wheels
Soon to come 07 BMW Z4M Coupe Black/Red
      02-02-2009, 08:47 AM   #11
epbrown
epbrown's Avatar
Like a lot of dealers, they'e mistaken. The airbags on the M wheels and the standard wheel are interchangeable, so you can re-use the original.
      02-10-2009, 04:30 PM   #12
nickpapa
nickpapa's Avatar
17
Drives: Z4 3.0
do you have to insert both screw drivers into the hole at the same time or can you do it one at a time?
do you just push and it unclips the airbag? trying to get a better idea on this as i am about to do the same swap
      02-11-2009, 04:52 PM   #13
ElegantSpoon
There I was balls deep in a...
ElegantSpoon's Avatar
24
Drives: BMW E90 320D
Its so easy! Took me about 5mins to do the entire thing! Just do one side at a time and it pops out, then remove the clips undo bolt and then redo!
      05-21-2009, 04:11 PM   #14
jojodivo
Drives: 2003 Z4 3.0i
I am about to do the same thing to my car. I have the multifunction wheel but don't really like how it looks. Was hoping to find someone who likes the look of the multifunction or wants to be able to control the radio from the wheel. I see your wheel does not have the multifunction inserts, wanna trade?
      10-04-2012, 01:18 PM   #15
goeslikeschnell
goeslikeschnell's Avatar
Drives: 2006 Z4 3.0si
Thanks for the DIY, just used it to install an M wheel!
      12-25-2012, 05:47 PM   #16
kleenE85
Drives: 2004 BMW Z4 3.0i
Literally just finished installing my new ///M wheel and this post was very helpful. Thank you for posting
      12-27-2012, 01:02 AM   #17
Z4-VILLA
Afghanistan
-23
Drives: Z4M Hardtop Roadster
Send a message via ICQ to Z4-VILLA
give the wheel a leatherique treatment to bring back the luster and newness of the leather, it should remove any dents from storage as well.
      10-22-2013, 09:39 PM   #18
Small Yellow
Track Addict
Small Yellow's Avatar
Taiwan
59
Drives: 2010 BMW M3 E92 | 2008 Z4M E86
Subbed.
BMW ///M3 Coupe
Completed November 16, 2009
Received December 29,2009
BMW //M Coupe
November 4, 2013
      03-30-2014, 10:34 PM   #19
wasupdu
wasupdu's Avatar
Drives: Z4 3.0, CLS63 AMG
Swapped out my stock Z4 wheel with the M wheel a couple days ago and LOVE the new wheel. My '05 wheel was disgusting from all the wear and Tischer had a deal I just couldn't resist...
The install was easy, but as the OP described, I had a tough time finding airbag release points with a screwdriver. After 5-6 mins I found the right release point and the left took less than 10 sec.
LOVE the new wheel. Feels so substantial and the stitching is great too.
2005 BMW Z4 Roadster 3.0 - Black Sapphire with Red Extended Leather / NAV / Premium & Sport Pkgs / 19" wheels / M steering wheel / Xenon
2013 Mercedes CLS63 AMG
      04-09-2014, 09:35 PM   #20
BlackSapphireZ
Z
wow my post lives on!
its been almsot 7 years...
2003 Z4 2.5i Sport
miss this car
      05-08-2014, 04:19 PM   #21
fullerra
fullerra's Avatar
Drives: 08 Z4M Coupe
test test  [0.00]
2008 BMW Z4MC  [0.00]
Wheel Removal
Thanks!
Just used this post to straighten out my wheel!
      07-25-2014, 06:01 PM   #22
Twisted Six
Twisted Six's Avatar
Drives: Z4si-coupe
Anyone know offhand what size socket is required for the wheel center nut? I need to remove mine Monday.
