Reply
      01-21-2013, 05:46 PM   #1
aestheticstorm
aestheticstorm's Avatar
Drives: '08 Z4 M Coupé (Sepang Bronze)
Different tire brand on front/rear... acceptable?
Is it just faux pas or will it have handling consequences? I'll save you the trouble and myself.
#1765/1815 — 1 of 68 Sepang Bronze / Black Nappa / Madeira Wood
19" Advan RS Dark Gun / Hankook Ventus V12 / H&R Springs / StopTech SS lines / StopTech Street Perf pads / R.E. Diablo / CF Grills / CDV Delete
aestheticstorm is offline   United_States
      01-21-2013, 06:14 PM   #2
Gtfour
Gtfour's Avatar
Drives: BMW E86 ///M
For the street, it's not that bad. I will have RE11 front and RS3 rear this summer.
For the track, try to avoid to mix different thread wear, tires brand. They won't react the same to temperature and won't grip/loose grip at the same time.
#1013 E86 M:: ESS VT1-445 : CSL headers : Performance Friction Z45/Z29 BBK : KW Clubsport : Hyperco 650/750 : CCW Classic's : Pirelli Tropheo & DH Slicks : 4.10 diff : Recaro Pole Position : Jaffster knob : AutoSolution SSK : OMP 1010 pedals : AIM Solo : Strong Strut braces : H&R front swaybar : APR CF splitter : APR GTC-200 CF wing : 42 Draft Design catch can : Custom hitch
Gtfour is offline   Canada
      01-21-2013, 06:24 PM   #3
aestheticstorm
But this is the case with the same tire anyway, isn't it? Front and rear dynamics are quite different. My main concern is tramlining. Reason I ask is I want 255 in front and the only tire I can find in that size is RE-11. Then NT05 on rear because they're cheaper.
Off Topic: How is the RE-11 vs RS3?
      01-21-2013, 06:36 PM   #4
Kgolf31
Kgolf31's Avatar
Drives: 2007 Z4MC, 2012 128i
RS3s have 255, and probably Star Specs. EDIT: Just saw you run 19s.
You get to the point where you get different slip angles, sure...the tires heat up differently weather it be inside tire, outside tire...front/rear.
But, if you get different tire, now you play with different sidewall deflections and slip angles. For example, RS3s require huge amounts of slip angle to get maximum grip, where as the Star Specs do not. With this, you will not satisfy the front w/out disrupting the rear...and vice versus
07 Z4M Coupe: 235/265 Hankook RS3, H&R E46 M3 30mm Front Sway Bar, Hawk HP+ Pads, Vorshlag Wheel Stud Conversion
12 128i Coupe: Stock, for now
Kgolf31 is offline   Reply With Quote
Reply
Forum Jump
