FORUMS
- 5
| 01-18-2013, 04:08 PM | #1 |
![]() Drives: 2006 BMW M COUPE Join Date: Dec 2008
How to remove dash panel - answer myself
![]() Here are the pictures - Remove the right hand vent and cup holder - there is a little phillips screw top right under a little cap and one behind the cup holder when its closed - so open the holder and take the screw out and pull the cup holder straight out. Next thread .
2006 M COUPE - one of 38 Imola Red produced for NA that year, ESS 455 Supercharger
| 01-18-2013, 04:22 PM | #2 |
Taking off dash - centre vent / radio cd
The upper vent has two metal clips on it in the M coupe and I imagine all Z -4 coupes are the same. Just place a thick credit card or piece of plastic down between the top of the vent and the dash. Slide it across the top pushing down and pulling out on the vent. The two clips will release as you push down and pop out as you pull out - pics attach
NExt thread
| 01-18-2013, 04:45 PM | #3 |
Panel removal
Why would one use 2 screws when you can use 6 - all different sizes - must be a german thing.
Anyway after you pull out the upper vent section there are 2 screws holding in the radio/cd player - pull it out as well and it is a little tight - place it up on the top of the dash or just pull it our so you can get at the 2 SCREWS behind the fascia holding the dash panel on @!@ Remove these 2 screws as well as the two at the top and all the screws holding the panel on are gone. Starting over on the passenger side reach in the hole where the side vent was removed - look in to the left with a flashlight or mirror and you can see the clip that holds this end on. It is a metal clip that slides DOWN through a square fitting on the back of the dash panel - I took a pic with a mirror so hope you can see it cause there is no way in hell you can pull that sucker off without wrecking something. Once its off pull out that end a bit and slide a screwdriver along between the dash panel and the lower dash = there are about 3 plastic insert clips on the top and bottom that snap in and hold it on - once those pop off the panel just lifts off. I think I will start a new thread to see what folks think about the area I am going to mount a boost gauge ![]()
![]() Last edited by drbvac; 01-18-2013 at 07:11 PM. Reason: more pic |
| 01-18-2013, 08:30 PM | #5 |
Bimmer Noob
Drives: 08 Z4MC;08 MBZ E350 4Matic Join Date: May 2010
Your timing is excellent!
Thanks!
![]() 08 Z4MC /// Prem Pkg, Zeck CDV, Stubby, RPI Scoop, Clutch Stop, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing, AFE Intake, CF Grill, ZHP Shift Knob, UUC Tranny Mounts, Stoptech SS brake lines, CF Badges |
| Bookmarks |
