Reply
      01-18-2013, 12:20 AM   #1
3point0
3point0's Avatar
Drives: 2005 z4 3.0
2005 BMW Z4  [2.00]
non-M diff and tranny oil grades
Doing Inspection 2 on my '05 3.0 automatic. Want to do a diff flush and a tranny flush, does anyone know what grade / brand / quantity of oils I should be buying? I've read Shipkiller's very informative pages and wanted peoples opinions on where I should be getting the stuff from and if there are alternatives.
2005 Z4 3.0 steptronic | TiSilver on Black | sport & premium package | 108s | Msport seats | wind deflector
OMP strut bar | blacked out emblems | de-french-fried | sound gen | DIY aux input | first aid boxes | stubby antenna | polished exhaust tips
3point0 is offline   Canada
      01-26-2013, 05:43 PM   #2
3point0
3point0's Avatar
Drives: 2005 z4 3.0
2005 BMW Z4  [2.00]
I just went to BMW to try and get the oil for the transmission. They wanted $45.95 per litre and I need 9 litres! Looks like I'll be sourcing it from somewhere else.
      01-27-2013, 07:44 AM   #3
rsutoratosu
Drives: Z4
There is usually a sticker that tells you what type you need on the ATF and search online. The diff I just used redline 75w90. Hope yours is the same
Here's a diff DIY I used
http://www.zpost.com/forums/showthread.php?t=79742
-Roranji
rsutoratosu is offline   Reply With Quote
      03-15-2013, 02:07 PM   #4
thelinux
Drives: 2008 Z4 3si
I bought transmission fluid (ZF Lifeguard6) for mine from CTSC.
http://www.thectsc.com/index.php?p=c...parent=58&pg=1
It's a lot cheaper than dealer.
I did a lot of reading about which ATF to use. There are some compatible ATF which are cheaper than lifeguard. But I did not want to take any chance on my expensive tranny over few dollars. So went with OEM fluid.
Redline ATF D4 is cheaper option but people's opinion seems vary. If you are going to use non - OEM fluid, I would do the complete flush not just drain and refill.
BTW if you are going to do just drain and refill, you dont need 9 liters. 6 liters seems enough.
thelinux is offline   United_States
      03-19-2013, 11:08 AM   #5
ludoZ4
Drives: Z4 3.0si
hi buddy,
find an expert, it will cost way less.
don't forget that u have to buy the oil filter too, it's not cheap at all !
ludoZ4 is offline   Reply With Quote
Reply
Forum Jump
