Reply
      01-12-2013, 02:11 AM   #1
iZ4vel
Repair Member
iZ4vel's Avatar
Drives: 03 Z4 2.5i
Help please! Fuel line disconnect?
I have a fuel leak where the fuel line connects to my fuel pressure regulator/fuel pump. My Haynes manual doesn't give instruction on how to disconnect the fuel line. I need to disconnect this fuel line because I'm most likely going to have to replace the fuel pressure regulator. I have tried everything from pushing the fuel line in, to turning the fuel line, to pulling on the fueling and I haven't had any success. If anyone know how to disconnect this fuel line please let me know. I drive a '03 Z4 2.5i. I made a video of the fuel line connector type, and also linked a picture of the new fuel pressure regulator's adapter, it appears to be a quick disconnect but obviously a generic fuel line removal tool won't work as the connector has 4 notches that block the inside. Maybe a special bmw tool? Or maybe it unscrews at its base? This is not held in by a metal clamp like on the 325i, it appears to be a push in type but it will not disconnect and it needs to because it is the source of the fuel leak. Thank you all for your help in advance!
Skip to 1:25 for fuel line connection.
http://www.youtube.com/watch?v=YuQzUkpNk_c
iZ4vel is offline
      01-12-2013, 08:03 AM   #2
Shipkiller
Shipkiller's Avatar
Drives: 2008 Z4MC & 2003 Z4 Roadster
What you have pictured is the fuel filter and pressure regulator. The fuel pump is snapped into its mount which is internal to the tank.
The BMW TIS (16 11 048) does not list any special tools to disconnect the fuel lines from the filter/regulator assembly. The only special too it lists is 16 1 020, to remove the outer cap on the fuel tank, which you already have done...
Shipkiller is offline   United_States
      01-12-2013, 10:04 AM   #3
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
TIS says to press the ring towards the fuel filter and then pull out the fuel line.
Tightening Torque 16 14 2AZ is 50 +/- 10 Nm.
bignosejim is offline   United_States
      01-13-2013, 11:51 PM   #4
iZ4vel
Repair Member
iZ4vel's Avatar
Drives: 03 Z4 2.5i
I tried to push the larger diameter ring into the fuel filter but it doesn't seem to move at all. There are two rings on the fuel line fitting (black piece), a smaller one in which the actual fuel connects to and then a larger one that doesn't move (meaning it's not spring loaded or quick disconnect type) but is a solid piece connected to the fitting. One thing that I did notice is that the beige looking piece that the fuel line connects to appears to have notches on it, perhaps to be turned out counter clockwise? I have tried this as well and this doesn't seem to do anything. The problem here is if I simply disconnect the fuel line from the fuel line fitting, it doesn't change the fact that the fitting is still going to need to be removed because my fuel leak is occurring exactly where the fitting is connected to the fuel pressure reg/fuel fitter. So eventually that thing is going to need to come off. One thing I could do is take off the fuel line, leave the fitting (black piece) attached to the fuel pressure reg/fuel filter and take it to my local dealer so that they can remove it for me so that it can be installed in the new fuel pressure reg. Any other idea's guys?
Attached are some pictures of the fitting...
Also notice how the pictures of the new part appear to have the fitment be installed by pushing it in and twisting it about 90* degrees to lock it... they appear to have a cross on them and 4 outer tabs to lock that cross in place.
iZ4vel is offline   Reply With Quote
Reply
Forum Jump
