FORUMS
- 5
| 01-05-2013, 11:48 PM | #1 |
Oil Level Question
Ok, I changed my oil and filter in my 2006 M Coupe and I very carefully put 5.5 Liters of Castrol 10w60 back into it. Started it and checked for leaks, no problem, shut it off and waited for a minute to check the level.
Drove it to the gas station and back, checked it again. 5.5 liters puts the oil level right at the low mark on my dipstick. Is this where I leave it?? My car does not use any oil between changes so that is not a concern but in my mind the car is low on oil at that level on the dipstick. Opinions??? |
| 01-06-2013, 07:49 AM | #2 |
Something is odd, it should be at least half way with 5.5
Alpinweiss '07 M Coupe •Eisenmann Sport-Ceramic Black•Diablo-X•Fabspeed Headers•VRS Hyper-Narrow rear wing•Autosolutions SSK•APR splitter•Tekarbon headlights•StrongStrut STB•KW Clubsport•Poly FCAB/RTAB•Volk Racing G2•Direzza ZII•Stoptech BBK c/w Cool Carbon pads
| 01-06-2013, 01:25 PM | #6 |
![]() ![]() ![]() ![]() Drives: 2007 Z4 M Coupe Join Date: Aug 2007
Castrol TWS 10W-60 is packaged in one liter containers not quarts.
S54 engine oil capacity and level chacking procedures found here: http://www.bimmerfest.com/forums/showthread.php?t=41599
Jim Millet
2007 E86 Z4 M Coupe/ZPP Premium Package/Nav System/Heated Seats/HD Radio/CDV Delete/Strong-Strut/TCK DA Coil Over Suspension/500# front; 600# rear/TCK Camber-Caster Plates ![]() |
| 01-06-2013, 03:45 PM | #8 |
M = Midlife Crisis
Drives: 2006 Z4MC Interlagos Join Date: May 2007
You mean the half (mark)
2006 Z4MC - #LL93158
SuperSprint Race Cans, RE X Pipe, Fabspeed Headers, OE STB, AS Shifter, Dave Z Modified CDV, Ground Control Coil Overs, Stoptech lines, Stoptech Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, ZHP Shift Knob, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM |
| 01-06-2013, 04:31 PM | #9 |
| 01-06-2013, 06:25 PM | #10 |
M = Midlife Crisis
S54 level is half. Most BMW techs overfill our cars...
| 01-06-2013, 10:23 PM | #11 | |
I started checking the oil 45 seconds after shutdown and continued checking it until about 2 minutes and it is right at the bottom mark on the dipstick. The oil was brand new and all the bottles were filled to the same level. According to the manual there is 1.3 - 1.4 liters between the bottom and top marks on the dipstick so if I fill it to the top mark that would mean 6.5 - 7.0 liters. Seems to be a bit much. I know it has 5.5 liters in it so I guess I will just drive it at the low mark..... |
| 01-08-2013, 02:14 AM | #12 |
![]() ![]() Drives: Sapphire Black/Black Z4Mc Join Date: Oct 2008
Unless you're checking the oil in incline I don't see why the oil level should be that low. Is there any chance that the temperature was really really cold, or things were a bit rushed, and there was a portion of oil left in each bottle that did not end up in the car? (Can't see how, but thinking out loud.)
In any case I might add another quarter bottle just bringing up a bit past the bottom fill line. IMO what matters is what can be measured with the dipstick.
![]() 2007 Sapphire Black Z4M / Apex EC7s / Eisenmann Exhaust / Euro Headers/Cat / Aero Sideskirts / DIY Stubby / Ultimate Pedals / AS SSK / RB Rotors / Other Stuff #1047 |
| 01-08-2013, 02:23 AM | #13 |
![]() ![]() ![]() ![]() Drives: '04 X5, '08 Z4MC Join Date: Apr 2010
What do you measured after letting it sit overnight? Mine usually measured on the low side even after 15-20 minutes of shutdown. However, it always measured near the middle when it has been left sitting overnight.
| 01-08-2013, 02:52 AM | #14 |
^Good question.
| 01-08-2013, 07:18 AM | #15 |
That's why there is a sticker under the hood with the idle, then 60 second shutdown procedure.
| 01-08-2013, 04:36 PM | #16 | |
And I was checking the level with the car sitting in the garage, which is flat so there couldn't be any incline issue. It was around 55 degrees when I changed the oil so I doubt I left much in the container on the pour. It is just weird because I never had this issue with either of my E46 M3s. One other questions - I am not the original owner of the car - is there any aftermarket way to increase oil capacity?? The car has a lot of mods on it but other than the Dinan throttle bodies, Dinan software and a J&B liteweight flywheel, I haven't found any other engine mods, mostly only chassis/diff stuff. |
| 01-08-2013, 04:56 PM | #17 |
Upgraded (larger) oil cooler is the only one I can think of. That would add some capacity. Take a look, but I doubt it's going to be easy just looking w/o a comparison, gmd2003 has one.
After we've exhausted all the possibilities and run down things like temp, incline, start/stop procedure, etc., I still think what the dipstick says is ultimately what matters.
| 01-08-2013, 10:41 PM | #18 | |
Car Geek
| 01-09-2013, 10:06 AM | #19 | |
I checked the level with the motor cold and it is about 1/3 above the low mark. I will add a little and drive it. The car has never used any oil so it should be fine. I was mainly curious if anyone had experienced this before. |
| 01-09-2013, 05:55 PM | #20 |
M = Midlife Crisis
5.5L should bring it to ~ halfway between the markings on the dip stick.
| 01-09-2013, 09:50 PM | #21 | |
Car Geek
| 01-10-2013, 11:57 AM | #22 | |
| Bookmarks |
